[postgis-users] Re:geos install problem
David Valentine
valentine at library.ucsb.edu
Fri Feb 20 09:54:47 PST 2004
You built GEOS with the LDFLAGS=-lstdc++
So, based on my experiences, solaris 8/9 installs are a problem.
I might be able to donate an old Sun 10 server to cause.
I assume you are using the compilers off the Sun Companion CD/Sunfreeware.com
I have not tried to do my own bootstrap build of GCC to see if that is the problem.
dv
James S reid wrote:
> hi - thanks for the suggestion but I still get an abortive make (and yes I
> did make clean first!!)
> anyone any additional thoughts? I seem to recall a warning about Bison
> versions somehere?
> cheers
> james
> ----- Original Message -----
> From: "David Valentine" <valentine at library.ucsb.edu>
> To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
> Sent: Thursday, February 19, 2004 4:22 PM
> Subject: Re: [postgis-users] Re:geos install problem
>>Funny, same problem with gcc 3.2/3.3
>>set a CFLAGS env variable
>>CFLAGS=-fPIC
>>James S reid wrote:
>>>apologies should have it:
>>>uname -a SunOS dearg 5.8 Generic_108528-27 sun4u sparc SUNW,Sun-Fire
>>>compiler gcc 2.95.3
>>>gmake 3.8
>>>cheers
>>>james
>>>From: "Paul Ramsey" <pramsey at refractions.net>
>>>Sent: Thursday, February 19, 2004 3:07 PM
>>>>Platform, compiler, etc?
>>>>On Thursday, February 19, 2004, at 01:41 AM, James S reid wrote:
>>>>>hi! Im trying to build postgis 0.8.1 and geos1.0 (against postgres
>>>>>7.4.1)- I
>>>>>can acehive this succesfully if i omit support for geos but if i set
>>>>>the
>>>>>flag to 2 and point to my geos install directory the make fails.
>>>>>I havent seen anything on the list that looks like an answer - help!!!
>>>>>below is a tail of the compilation errors and exit codes:
>>>>>geos::GeometryFactory::createPolygon(geos::LinearRing *,
>>>>>vector<geos::Geometry *, allocator<geos::Geometry *> > *) 0x1a14
>>>>>postgis_geos_wrapper.o
>>>>>geos::GEOSException type_info node 0x24 postgis_geos_wrapper.o
>>>>>geos::GEOSException type_info node 0x2c postgis_geos_wrapper.o
>>>>>geos::LineString::getCoordinatesRO(void) const0x5dd8
>>>>>geos::LineString::getCoordinatesRO(void) const0x5ed0
>>>>>geos::BasicCoordinateList::BasicCoordinateList(int)0x978
>>>>>geos::BasicCoordinateList::BasicCoordinateList(int)0x1680
>>>>>geos::BasicCoordinateList::BasicCoordinateList(int)0x181c
>>>>>geos::IntersectionMatrix::toString(void)0x2e58
>>>>>geos::GeometryFactory::getPrecisionModel(void) const0x154
>>>>>geos::GEOSException type_info function0x18
>>>>>geos::GeometryFactory::createLineString(geos::CoordinateList const
>>>>>*)0xa88
>>>>>geos::GeometryFactory::createPoint(geos::Coordinate const &)0x708
>>>>>geos::GeometryFactory::GeometryFactory(geos::PrecisionModel const *,
>>>>>int)0x48 postgis_geos_wrapper.o
>>>>>geos::PrecisionModel::PrecisionModel(void)0x34
>>>>>geos::GeometryFactory::createMultiLineString(vector<geos::Geometry *,
>>>>>allocator<geos::Geometry *> > *) 0x1088
>>>>>geos::GeometryFactory::createMultiPolygon(vector<geos::Geometry *,
>>>>>allocator<geos::Geometry *> > *) 0xd84
>>>>>geos::GeometryFactory::toGeometry(geos::Envelope *,
>>>>>geos::PrecisionModel *,
>>>>>int)0x164 postgis_geos_wrapper.o
>>>>>geos::GeometryFactory::createMultiPoint(vector<geos::Geometry *,
>>>>>allocator<geos::Geometry *> > *) 0x138c
>>>>>geos::Envelope::Envelope(double, double, double, double)0x120
>>>>>geos::GeometryFactory::buildGeometry(vector<geos::Geometry *,
>>>>>allocator<geos::Geometry *> > *) 0x418
>>>>>geos::GeometryFactory::createLinearRing(geos::CoordinateList *)
>>>>>0x1798
>>>>>0x1944
>>>>>ld: fatal: relocations remain against allocatable but non-writable
>>>>>sections
>>>>>collect2: ld returned 1 exit status
>>>>>gmake: *** [libpostgis.so.0.8] Error 1
>>>>>thoughts welcome : )
>>>>>James S Reid
>>>>>GeoData Services
>>>>>EDINA
>>>>>University of Edinburgh
>>>>>Main Library
>>>>>George Square
>>>>>EH8 9LJ
>>>>>tel: +44 (0) 131 651 1383
>>>>>fax: +44 (0) 131 650 3308
>>>>>email: james.reid at ed.ac.uk
>>>>>"Programming today is a race between software engineers striving
>>>>>to build bigger and better idiot-proof programs, and the Universe
>>>>>trying to produce bigger and better idiots.
>>>>>So far, the Universe is winning."
>>>>> Rich Cook
>>>>>_______________________________________________
>>>>>postgis-users mailing list
>>>>>http://postgis.refractions.net/mailman/listinfo/postgis-users
>>>> Paul Ramsey
>>>> Refractions Research
>>>> Email: pramsey at refractions.net
>>>> Phone: (250) 885-0632
