[postgis-users] Re:geos install problem
James S reid
james.reid at ed.ac.uk
Mon Feb 23 01:24:28 PST 2004
hi again - actually looking at the ouput in the config.log with the LDFLAGS
set it fails :
configure:2288: checking for C compiler default output
configure:2291: gcc -fPIC -lstdc++ conftest.c >&5
configure:2294: $? = 0
configure:2340: result: a.out
configure:2345: checking whether the C compiler works
configure:2351: ./a.out
ld.so.1: ./a.out: fatal: libstdc++.so.2.10.0: open failed: No such file or
directory
./configure: line 1: 14393 Killed ./$ac_file
configure:2354: $? = 137
configure:2363: error: cannot run C compiled programs.
so I guess geos wont build and ergo niether will postgis with geos
support!!!
do you think this would go away with a later version of the GNU compiler (we
are on 2.95.3) which was the system bundled version I believe...?
cheers
james
----- Original Message -----
From: "David Valentine" <valentine at library.ucsb.edu>
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Sent: Friday, February 20, 2004 5:54 PM
Subject: Re: [postgis-users] Re:geos install problem
> You built GEOS with the LDFLAGS=-lstdc++
> So, based on my experiences, solaris 8/9 installs are a problem.
> I might be able to donate an old Sun 10 server to cause.
> I assume you are using the compilers off the Sun Companion
CD/Sunfreeware.com
> I have not tried to do my own bootstrap build of GCC to see if that is the
problem.
> dv
> James S reid wrote:
> > hi - thanks for the suggestion but I still get an abortive make (and yes
I
> > did make clean first!!)
> > anyone any additional thoughts? I seem to recall a warning about Bison
> > versions somehere?
> > cheers
> > james
> > Sent: Thursday, February 19, 2004 4:22 PM
> >>Funny, same problem with gcc 3.2/3.3
> >>set a CFLAGS env variable
> >>CFLAGS=-fPIC
> >>James S reid wrote:
> >>>apologies should have it:
> >>>uname -a SunOS dearg 5.8 Generic_108528-27 sun4u sparc SUNW,Sun-Fire
> >>>compiler gcc 2.95.3
> >>>gmake 3.8
> >>>cheers
> >>>james
> >>>From: "Paul Ramsey" <pramsey at refractions.net>
> >>>Sent: Thursday, February 19, 2004 3:07 PM
> >>>>Platform, compiler, etc?
> >>>>On Thursday, February 19, 2004, at 01:41 AM, James S reid wrote:
> >>>>>hi! Im trying to build postgis 0.8.1 and geos1.0 (against postgres
> >>>>>7.4.1)- I
> >>>>>can acehive this succesfully if i omit support for geos but if i set
> >>>>>the
> >>>>>flag to 2 and point to my geos install directory the make fails.
> >>>>>I havent seen anything on the list that looks like an answer -
help!!!
> >>>>>below is a tail of the compilation errors and exit codes:
> >>>>>geos::GeometryFactory::createPolygon(geos::LinearRing *,
> >>>>>vector<geos::Geometry *, allocator<geos::Geometry *> > *) 0x1a14
> >>>>>postgis_geos_wrapper.o
> >>>>>geos::GEOSException type_info node 0x24
> >>>>>geos::GEOSException type_info node 0x2c
> >>>>>geos::LineString::getCoordinatesRO(void) const0x5dd8
> >>>>>geos::LineString::getCoordinatesRO(void) const0x5ed0
> >>>>>geos::BasicCoordinateList::BasicCoordinateList(int)0x978
> >>>>>geos::BasicCoordinateList::BasicCoordinateList(int)0x1680
> >>>>>geos::BasicCoordinateList::BasicCoordinateList(int)0x181c
> >>>>>geos::IntersectionMatrix::toString(void)0x2e58
> >>>>>geos::GeometryFactory::getPrecisionModel(void) const0x154
> >>>>>geos::GEOSException type_info function0x18
> >>>>>geos::GeometryFactory::createLineString(geos::CoordinateList const
> >>>>>*)0xa88
> >>>>>geos::GeometryFactory::createPoint(geos::Coordinate const &)0x708
> >>>>>geos::GeometryFactory::GeometryFactory(geos::PrecisionModel const *,
> >>>>>int)0x48 postgis_geos_wrapper.o
> >>>>>geos::PrecisionModel::PrecisionModel(void)0x34
> >>>>>geos::GeometryFactory::createMultiLineString(vector<geos::Geometry *,
> >>>>>allocator<geos::Geometry *> > *) 0x1088
> >>>>>geos::GeometryFactory::createMultiPolygon(vector<geos::Geometry *,
> >>>>>allocator<geos::Geometry *> > *) 0xd84
> >>>>>geos::GeometryFactory::toGeometry(geos::Envelope *,
> >>>>>geos::PrecisionModel *,
> >>>>>int)0x164 postgis_geos_wrapper.o
> >>>>>geos::GeometryFactory::createMultiPoint(vector<geos::Geometry *,
> >>>>>allocator<geos::Geometry *> > *) 0x138c
> >>>>>geos::Envelope::Envelope(double, double, double, double)0x120
> >>>>>geos::GeometryFactory::buildGeometry(vector<geos::Geometry *,
> >>>>>allocator<geos::Geometry *> > *) 0x418
> >>>>>geos::GeometryFactory::createLinearRing(geos::CoordinateList *)
> >>>>>0x1798
> >>>>>0x1944
> >>>>>ld: fatal: relocations remain against allocatable but non-writable
> >>>>>sections
> >>>>>collect2: ld returned 1 exit status
> >>>>>gmake: *** [libpostgis.so.0.8] Error 1
> >>>>>thoughts welcome : )
> >>>>>James S Reid
> >>>>>GeoData Services
> >>>>>EDINA
> >>>>>University of Edinburgh
> >>>>>Main Library
> >>>>>George Square
> >>>>>EH8 9LJ
> >>>>>tel: +44 (0) 131 651 1383
> >>>>>fax: +44 (0) 131 650 3308
> >>>>>email: james.reid at ed.ac.uk
> >>>>>"Programming today is a race between software engineers striving
> >>>>>to build bigger and better idiot-proof programs, and the Universe
> >>>>>trying to produce bigger and better idiots.
> >>>>>So far, the Universe is winning."
> >>>>> Rich Cook
> >>>>>_______________________________________________
> >>>>>postgis-users mailing list
> >>>>>http://postgis.refractions.net/mailman/listinfo/postgis-users
> >>>> Paul Ramsey
> >>>> Refractions Research
> >>>> Email: pramsey at refractions.net
> >>>> Phone: (250) 885-0632
