[postgis-users] Help on Postgresql 7.4.1 install with postgis 0.81
Darren Houston dhouston at beyondcompliance.ca
Sun Feb 22 02:25:53 PST 2004
Hello Jeremy,
Am I correct in assuming you installed PostgreSQL 7.4.1 from RPMs?
You can install PostGIS with an RPM installed PostgreSQL, but it takes a little
ingenuity. If you installed PostgreSQL from source, then PostGIS is a snap.
E-mail back telling how PostgreSQL was installed and I'll help you out.
Jeremy Palmer <jpalmer at paradise.net.nz> said:
> Hi,
> I'm new to the world of postgis and postgreSQL. Up until now I have used the
> redhat 9.0 rpms for the install of postgis, geos and proj. However the rpms
> have only been compiled for postgres 7.3.1 and I wanted to use the latest
> version of 7.4.1. I have downloaded and installed all of the sources. My
> question is that with postgresql, postgis, proj and geos it seems the
> configure scripts by default install the files to /usr/local/lib and
> /usr/local/pgsql, and as far as I can tell I think under the redhat the
> files should be going to /usr/bin and /usr/bin and postgresql data directory
> should be in the /var/lib/pgsql/? Could someone please show me how to
> configure postgresql, postgis, geos and proj scripts so that the "make
> install" of the sources will install into the correct directories. The
> configure options are a little confusing to me!
> Thank you very much for your time.
> Jeremy
> postgis-users mailing list
Darren Houston
