[postgis-users] Problem with installation
Mario Soto Cordones
mario_soto at venezolanadeavaluos.com
Tue Feb 24 15:10:12 PST 2004
OK.
but i install a postgis using a RMP package but not work
thank you
Mario
chodgson at refractions.net dijo:
> You need to download the source for postgresql, and compile and install it
> from
> that source. Then, untar the postgis source into the contrib directory of
> the
> _postgresql_source_directory_ - this is not /usr/share/pgsql/contrib/!! It
> should be something like /usr/local/src/postgresql-7.4.1/
> You have probably installed postgresql using an RPM - this is not going to
> work
> with the postgis source install. There are some postgis RPMs available if
> you
> have a compatible version of Linux.
> Chris
> Quoting Mario Soto Cordones <mario_soto at venezolanadeavaluos.com>:
>> postgresql work very good, but now want install postgis but not can
>> becose the next error
>> [postgis-0.8.1]# make
>> >>> Makefile:38: ../../src/Makefile.global: No existe el fichero o el
>> >>> directorio
>> >>> Makefile:145: /src/Makefile.shlib: No existe el fichero o el
>> directorio
>> >>> make: *** No hay ninguna regla para construir el objetivo
>> >>> `/src/Makefile.shlib'. Alto.
>> thank you for your help... but no understand what this the error
>> Mario Soto
>> TECHER Jean David dijo:
>> > Hi
>> > Did you try to configure postgresql and try make for postgresql before
>> > compiling postgis
>> > Configure should create the makefile you need
>> > TECHER JEAN DAVID
>> > - Responsable Informatique 01MAP -
>> > e-mail:davidtecher at yahoo.fr
>> > Tél: 06 85 37 36 75
>> > Site PostGIS: http://techer.pascal.free.fr/postgis/index.htm
>> > -----Message d'origine-----
>> > De : postgis-users-bounces at postgis.refractions.net
>> > [mailto:postgis-users-bounces at postgis.refractions.net]De la part de
>> > Mario Soto Cordones
>> > Envoyé : mardi 24 février 2004 20:48
>> > À : postgis-users at postgis.refractions.net
>> > Objet : Re: [postgis-users] Problem with installation
>> > Hi
>> > i do this but not work
>> > any idea
>> > Paul Ramsey dijo:
>> >> Yes, please read the installation directions in the README.postgis
>> file
>> >> carefully, in particular this sentence:
>> >> "To install the module, move this directory to the "contrib"
>> directory
>> >> of your
>> >> PostgreSQL source installation. "
>> >> Paul
>> >> On Tuesday, February 24, 2004, at 11:29 AM, Mario Soto Cordones
>> wrote:
>> >>> Hi...
>> >>> when try to install postgis this say
>> >>> directorio
>> directorio
>> >>> any idea
>> >>> Thank
>> >>> Ing. Mario Soto Cordones
>> >>> Venezolana de Avaluos
>> >>> www.venezolanadeavaluos.com
>> >>> _______________________________________________
>> >>> postgis-users mailing list
>> >>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> >> Paul Ramsey
>> >> Refractions Research
>> >> Email: pramsey at refractions.net
>> >> Phone: (250) 885-0632
