[postgis-users] geos result sets
Martin Davis
mbdavis at VividSolutions.com
Wed Feb 25 10:23:43 PST 2004
I thought I better leap to the defence of JTS/GEOS. I've analyzed the
situation and (no surprise to me) found that the results from GEOS are
correct. The Within=FALSE result is caused by a slight difference in
the vertices in the two coverages.
I've attached a full analysis (with screenshots from JUMP).
I have no idea why ArcView gives a different result - you'll have to ask
ESRI 8^)
Martin Davis, Senior Technical Architect
Vivid Solutions Inc.
Suite #1A-2328 Government Street Victoria, B.C. V8T 5G5
Phone: (250) 385 6040 - Local 308 Fax: (250) 385 6046
> -----Original Message-----
> From: James S reid [mailto:james.reid at ed.ac.uk]
> Sent: Wednesday, February 25, 2004 1:09 AM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] geos result sets
> hi - thanks and I appreciate that your times at a premium -
> Ive checked that the geoms are valid and run the follwing sql
> (2 tables 1=large poly,1=small polys (8 polys):
> test=# select small.* into temp from small,large where
> within(small.the_geom,large.the_geom) = TRUE;
> dumping temp gives sthe GEOS result set seen in the
> screenshot attached (along with the sql load files for the
> original shapes).
> as you can see - AV gets all eight polys and GEOS only the seven?
> Im I missing something or is there a bug?
> cheers
> james
> ----- Original Message -----
> From: "David Blasby" <dblasby at refractions.net>
> To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
> Sent: Tuesday, February 24, 2004 5:48 PM
> > Why dont you send us the actual query thats going wrong?
> > ie. something like:
> > select within(<polygon 1>,<polygon 2>);
> > I need to see what <polygon 1> and <polygon 2> are to do
> any testing.
> > Saying GEOS and ARC have a different answer isnt enough to
> diagnose a
> > problem - I need a specific example.
> > I, unfortunately, dont have time to sift through your data
> in PostGIS
> > and ARC to find differences.
> > Did you check to see if your geometries are valid (ie. select
> > isvalid(the_geom) from <table>;)?
> > dave
> > postgis-users mailing list postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
Name: Case Study - Unexpected Spatial Relationship in Coverages.doc
Type: application/msword
Desc: Case Study - Unexpected Spatial Relationship in Coverages.doc
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20040225/f533f732/attachment.doc>
