[postgis-users] geos result sets
David Blasby
dblasby at refractions.net
Wed Feb 25 10:42:25 PST 2004
Martin Davis wrote:
> I thought I better leap to the defence of JTS/GEOS. I've analyzed the
> situation and (no surprise to me) found that the results from GEOS are
> correct. The Within=FALSE result is caused by a slight difference in
> the vertices in the two coverages.
> I've attached a full analysis (with screenshots from JUMP).
> I have no idea why ArcView gives a different result - you'll have to ask
> ESRI 8^)
Thanks for looking at that, martin.
dave
