[postgis-users] Spatial Operator Documentation (was geos result sets)
Wood Brent
pcreso at pcreso.com
Wed Feb 25 15:17:08 PST 2004
This is a down to earth example of topology in action, I have used it in
workshops to illustrate a classic question.
I'm interested to know how GEOS answers the question, as depending on your
predicate, either can be correct.
There is a broom in a closet in, the closet is in a room in a house. (assume
the closet, room & house are polygons, the closet in the room in the house, the
broom can be a point)
Question: Is the broom in the house?
(general answer = yes)
There is a fish in a pond in an island in a lake. Same topology as above.
Question: Is the fish in the lake?
(general answer = no)
So, depending on the user's requirements, either answer can be correct.
Does PostGIS/GEOS topology support islands? ie, a complex polygon is defined by
an outer boundary with holes inside or as an outer boundary only. As I
understand it, only simple polygons are supported.
In this case I presume sub-queries can be used to test for containment in the
outer polygon and no containment in any polygons contained by the outer
polygon.
Has anyone implemented a system using PostGIS where the topological
relationships of complex polygons islands are supported, so that the fish IS
NOT in the lake but IS in the pond, as well as a system which returns the broom
IS in the house?
Aside: I am pleased to see the separation of touch & intersect as functions :-)
Cheers
Brent Wood
