Réf. : [postgis-users] Creating a C spi function that calls Postgis functions
bsimon at loxane.com bsimon at loxane.com
Thu Feb 26 02:25:56 PST 2004
As I don't get any answers, I think you may need more information on my
problem ;-) :
I'd like to get the X coordinate for a each point of a linestring :
Here is a part of my code :
        geom = (GEOMETRY *)PG_DETOAST_DATUM(datum);
        offsets = (int32 *) ( ((char *) &(geom->objType[0] ))+
sizeof(int32) * geom->nobjs ) ;
                        for (k=0; k< geom->nobjs; k++)
                                o = (char *) geom + offsets[k] ;
                                type =  geom->objType[k];
                                if (type == LINETYPE)
                                    line = (LINE3D *)o;
                                    for(l=0;l<coord.NbCoord;l++){
                                        point.x =
DatumGetFloat8(x_point((GEOMETRY *) make_oneobj_geometry(sizeof(POINT3D),
  (char *)&line->points[k+1],
      POINTTYPE,
      geom->is3d,
      geom->SRID,
      geom->scale,
      geom->offsetX,
      geom->offsetY)));
Here is how I compile my code :
gcc -O2 -fno-strict-aliasing -Wall -Wmissing-prototypes
-Wmissing-declarations -I/usr/src/postgresql-7.4.1-3/src/include  -c -o
MyFunc.o MyFunc.c
dlltool --export-all --output-def MyFunc.def MyFunc.o
dllwrap -o gdf2ToGdf1.dll --dllname MyFunc.dll \
--def MyFunc.def MyFunc.o \
/usr/src/postgresql-7.4.1-3/src/utils/dllinit.o \
-L/usr/src/postgresql-7.4.1-3/contrib/postgis-0.8.1/ -lpostgis \
-L/usr/src/postgresql-7.4.1-3/src/backend -lpostgres \
Here is how I create the function :
CREATE FUNCTION MyFunc() RETURNS integer
      AS '/home/bsimon/functions/MyFunc'
      LANGUAGE 'c';
Here is the error I get :
ERROR:  could not load library "/home/bsimon/functions/MyFunc.dll":
dlopen: Win32 error 126
I hope this could help !!!
Thanks.
B.S.
Envoyé par : postgis-users-bounces at postgis.refractions.net
25/02/2004 11:45
Veuillez répondre à PostGIS Users Discussion
        Pour :  postgis-users at postgis.refractions.net
        cc :
        Objet : [postgis-users] Creating a C spi function that calls Postgis    functions
I 've written a C spi function that connects to a base, retrieves some
geometries and does some proccessing on them. Everything is Ok so far.
The problem occurs when in my processing algorithm I try to use some
Postgis functions (such as "x_point" or "make_oneobj_geometry"). I manage
to link my code with postgis export library but I can't figure out why my
CREATE FUNCTION statement fails !
here is the error I get when I try to create the function :
dlopen: Win32 error 126   (I use cygwin)
Any ideas ??
B.S
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20040226/8d8dccfc/attachment.html>
