[postgis-users] postgis install error [compile-time] (better formatted log)
Paul Ramsey
pramsey at refractions.net
Fri Feb 27 11:41:40 PST 2004
The unspoken, but assumed fact is that if you have a postgresql source
tree, you have installed your software from that tree, so the tree you
are building postgis against has had ./configure ; make ; make install
run against it.
kenman wrote:
> here is my setup
> mandrake 9.2
> postgresql 7.4.1 [already installed]
> postgis 8.1
> i originally did this with a redhat install but had the same error. i really
> thought something was wrong with the latest redhat 9 so i redid the system to
> install mandrake 9.2 but i still get these errors. everything was compiled
> from source i never use rpms. perhaps these versions are just too new and not
> compatible yet? can anybody reccommend a working set of versions to install?
> anybody could reccomend their preference of linux? or is mandrake favorable to
__
| Paul Ramsey
| Refractions Research
| Email: pramsey at refractions.net
| Phone: (250) 885-0632
\_
