[postgis-users] Upgrade PostGIS/GEOS
Paul Ramsey
pramsey at refractions.net
Mon Jan 12 07:41:53 PST 2004
Generally speaking, for small upgrades, yes.
Two things happen when you do an in-place upgrade of the code:
- If there has been a change in the on disk structure, nothing will
work. However, there has not been a structure change for quite a long
time (The 0.6 to 0.7 upgrade was the last one, if I recall correctly.)
- You will not have access to any new functions unless you carefully
add the new functions from the SQL file. You will have access to bug
fixes in existing C functions, but not in the PL/PgSQL functions
(because those are in the SQL file). A careful hand drop / load of the
new SQL functions could be done with a little detail work.
P.
On Monday, January 12, 2004, at 05:11 AM, Düster Horst wrote:
> I'm working with GEOS Version 20031209 and I want to update PostGIS
> with the
> newst GEOS Version from CVS. I don't want to Upgrade the whole
> database due
> to the many sequences, views, tables etc. residing in this database.
> Is it possible to recompile/install PostGIS (the running Version)/GEOS
> (CVS)
> without a dump of the whole database?
> Regards
> Horst
> postgis-users mailing list
Paul Ramsey
Refractions Research
Email: pramsey at refractions.net
Phone: (250) 885-0632
