[postgis-users] Upgrade PostGIS/GEOS
Jeff Hoffmann
jeff at propertykey.com
Mon Jan 12 07:54:48 PST 2004
Paul Ramsey wrote:
> - You will not have access to any new functions unless you carefully add
> the new functions from the SQL file. You will have access to bug fixes
> in existing C functions, but not in the PL/PgSQL functions (because
> those are in the SQL file). A careful hand drop / load of the new SQL
> functions could be done with a little detail work.
> P.
Something I've always wondered about is if there is a good reason why
the function declarations in postgis.sql don't use "CREATE OR REPLACE
FUNCTION" instead of a plain "CREATE FUNCTION". That would fix the
problem, wouldn't it?
Jeff Hoffmann
PropertyKey.com
