[postgis-users] undefined symbol: errstart
Paul Ramsey
pramsey at refractions.net
Mon Jan 19 18:22:44 PST 2004
Google is almost, but not completely, unhelpful. There is *one* reference to
your error, albeit in Polish. From what I can muddle through, the response is
that there is a conflict between the 7.3 and 7.4 postgresql versions.
So... does your fresh install of RedHat 9 have some postgresql rpms sitting on
it still?
rpm -qa | grep postgres
If there are any, remove them, so your from-source install can have the field
clear to itself.
Paul
On January 19, 2004 05:50 pm, Matthew Haines wrote:
> Freshly installed Redhat 9.0, installing Postgis 0.8.0 against PostgreSQL
> 7.4 freshly compiled from /usr/src into /usr/local using only the defaults
> and exactly according to the scripts in the docs for both programs.
> When I execute
> psql -d nycpr -f postgis.sql
> I get
> psql:postgis.sql:41: ERROR: Load of file
> /usr/local/pgsql/lib/libpostgis.so.0.8 failed:
> /usr/local/pgsql/lib/libpostgis.so.0.8: undefined symbol: errstart
