[postgis-users] Error executing postgis.sql
Tyler Mitchell
TMitchell at lignum.com
Tue Jan 20 08:56:26 PST 2004
Danny, could you tell us more about your setup? Did you compile postgresql
yourself or are you using a stock version? I assume you're on some *nix
operating system. Are you sure that the postgis.sql that you are loading
is from the same version of the postgis libraries you installed?
postgis-users-bounces at postgis.refractions.net wrote on 01/20/2004 06:54:06
AM:
> Hey all...
> I am trying to import postgis.sql into the database I setup and I
> get an error about 3/4 of the way through.
> I am getting:
> psql:postgis.sql:1004: ERROR: could not find function "centroid" in
> file "/opt/WM/db/lib/postgresql/libpostgis.so.0.8"
> Any thoughts would be very appreciated. I checked and the
> libpostgis.so.0.8 file is included in that directory. I tried
> looking through the list to see if this was a past issue, but
> couldn't find anything.
> ~Danny
