[postgis-users] Error executing postgis.sql
TECHER Jean David davidtecher at yahoo.fr
Tue Jan 20 09:58:17 PST 2004
Did you put USE_GEOS=1 when you compiled postgis?
TECHER Jean David
Tel: 06-85-37-36-75
e-mail: davidtecher at yahoo.fr
Site PostGIS: http://techer.pascal.free.fr/postgis/index.htm
-----Message d'origine-----
De : postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net]De la part de
Tyler Mitchell
Envoye : mardi 20 janvier 2004 17:56
A : PostGIS Users Discussion
Objet : Re: [postgis-users] Error executing postgis.sql
Danny, could you tell us more about your setup?  Did you compile postgresql
yourself or are you using a stock version?  I assume you're on some *nix
operating system.  Are you sure that the postgis.sql that you are loading
is from the same version of the postgis libraries you installed?
postgis-users-bounces at postgis.refractions.net wrote on 01/20/2004 06:54:06
AM:
> Hey all...
> I am trying to import postgis.sql into the database I setup and I
> get an error about 3/4 of the way through.
> I am getting:
> psql:postgis.sql:1004: ERROR:  could not find function "centroid" in
> file "/opt/WM/db/lib/postgresql/libpostgis.so.0.8"
> Any thoughts would be very appreciated. I checked and the
> libpostgis.so.0.8 file is included in that directory. I tried
> looking through the list to see if this was a past issue, but
> couldn't find anything.
> ~Danny
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
