[postgis-users] error loading postgis.sql on OS X 10.3 server
Paul Ramsey
pramsey at refractions.net
Fri Jan 23 11:00:27 PST 2004
Thrills and chills. I am beginning to understand my Java loving friend Martin
and his rants about platform dependance and C/C++.
So your dynloader does not appear to be loading the C++ library at runtime for
the postgis library... if you were a Linux user, I would have advice. As an
OS/X user... try to figure out why your dynloader is not making the
connection. Your postgis library clearly knows it has a dependency on c++,
your loader just is not resolving it.
P.
On January 23, 2004 10:27 am, Alex Rice wrote:
> Hi I'm back. Trying to upgrade my PostGIS installation it turned out to
> be tough to get the pieces all together, as usual!
> The error, shown below, sounds as if my Pgsql is not compiled with C++
> support, but I did indicate stdc++ on the configure options for Pgsql
> (for GEOS support) Any ideas where I went wrong?
> gcc -v
> Reading specs from /usr/libexec/gcc/darwin/ppc/3.3/specs
> Thread model: posix
> gcc version 3.3 20030304 (Apple Computer, Inc. build 1495)
> PostgreSQL 7.4.1
> ./configure --with-perl --with-rendezvous --without-readline
> LDFLAGS="-lstdc++ -L/usr/local/lib"
> PostGIS 0.8.1
> Makefile: USE_PROJ = 0, GEOS = 1, USE_STATS = 0
> Here is the error loading postgis.sql:
> # /usr/local/pgsql/bin/psql -U postgres -f
> /usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql -d
> aps
> BEGIN
> message
> PL/PgSQL is installed.
> (1 row)
> psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:
> 44: NOTICE: type "histogram2d" is not yet defined
> DETAIL: Creating a shell type definition.
> 44: ERROR: could not load library
> "/usr/local/pgsql/lib/libpostgis.so.0.8": dyld:
> /usr/local/pgsql/bin/postmaster Undefined symbols:
> __ZNSs20_S_empty_rep_storageE
> __ZNSs4_Rep11_S_max_sizeE
> __ZNSs4_Rep11_S_terminalE
> __ZNSt24__default_alloc_templateILb1ELi0EE12_S_force_newE
> __ZNSt24__default_alloc_templateILb1ELi0EE12_S_free_listE
> __ZNSt24__default_alloc_templateILb1ELi0EE22_S_node_allocator_lockE
> __ZTIPv
> __ZTVN10__cxxabiv117__class_type_infoE
> __ZTVN10__cxxabiv119__pointer_type_infoE
> __ZTVN10__cxxabiv120__si_class_type_infoE
> __ZTVN10__cxxabiv121__vmi_class_type_infoE
> ___cxa_pure_virtual
> ___gxx_personality_v0
> 49: ERROR: current transaction is aborted, commands ignored until end
> of transaction block
> ... snip rest of errors ..
> Alex Rice, Software Developer
> Architectural Research Consultants, Inc.
> <http://ARCplanning.com>
> postgis-users mailing list
