[postgis-users] Check constraint violation using buffer()
Gary Sherman
sherman at mrcc.com
Fri Jan 23 11:07:17 PST 2004
I'm attempting to buffer a LINESTRING layer and insert the resulting
rows into a new table. The source layer has ~5,000 records. This process
(buffer and insert) worked on a small layer with only 27 features.
Details below. Any suggestions?
Source table:
gis_data=# \d majrivers
Table "public.majrivers"
Column | Type | Modifiers
gid | integer |
length | double precision |
decription | character varying(29) |
the_geom | geometry |
Check constraints:
"$1" CHECK (srid(the_geom) = -1)
"$2" CHECK (geometrytype(the_geom) = 'LINESTRING'::text OR the_geom
IS NULL)
Target table:
gis_data=# \d majrivers_buffercrash
Table "public.majrivers_buffercrash"
gid | integer |
Check constraints:
"$2" CHECK (geometrytype(the_geom) = 'POLYGON'::text OR the_geom IS
NULL)
gis_data=# insert into majrivers_buffercrash select gid,
buffer(the_geom,1000.0) from public.majrivers
gis_data-# ;
ERROR: new row for relation "majrivers_buffercrash" violates check
constraint "$2"
-gary
Gary Sherman <sherman at mrcc.com>
QGIS: http://qgis.org
