[postgis-users] Check constraint violation using buffer()
Paul Ramsey pramsey at refractions.net
Fri Jan 23 11:10:06 PST 2004
Try creating a table with a looser constraint (geometry type 'GEOMETRY') or
drop the constraint. Then run your test. Then test the geometry types of all
the resultants. Probably an odd type coming out, like a GEOMETRYCOLLECTION or
MULTIPOLYGON or something.
On January 23, 2004 11:07 am, Gary Sherman wrote:
> I'm attempting to buffer a LINESTRING layer and insert the resulting
> rows into a new table. The source layer has ~5,000 records. This process
> (buffer and insert) worked on a small layer with only 27 features.
> Details below. Any suggestions?
> Source table:
> gis_data=# \d majrivers
>             Table "public.majrivers"
>    Column   |         Type          | Modifiers
>  gid        | integer               |
>  length     | double precision      |
>  decription | character varying(29) |
>  the_geom   | geometry              |
> Check constraints:
>     "$1" CHECK (srid(the_geom) = -1)
>     "$2" CHECK (geometrytype(the_geom) = 'LINESTRING'::text OR the_geom
> IS NULL)
> Target table:
> gis_data=# \d majrivers_buffercrash
> Table "public.majrivers_buffercrash"
>  gid      | integer  |
> Check constraints:
>     "$2" CHECK (geometrytype(the_geom) = 'POLYGON'::text OR the_geom IS
> NULL)
> gis_data=# insert into majrivers_buffercrash select gid,
> buffer(the_geom,1000.0) from public.majrivers
> gis_data-# ;
> ERROR:  new row for relation "majrivers_buffercrash" violates check
> constraint "$2"
> -gary
