[postgis-users] Trouble compiling PostGIS with GEOS on IA64
Pavel Velikhov
velikhov at sdsc.edu
Fri Jan 23 12:38:42 PST 2004
I get the following linking error, when I compile PostGIS with GEOS:
gcc -O2 -fno-strict-aliasing -Wall -Wmissing-prototypes
-Wmissing-declarations -g -fexceptions -I. -DFRONTEND
-DSYSCONFDIR='"/usr/local/pgsql/etc"' -DUSE_VERSION=74
-I/usr/local/include/geos -DUSE_GEOS -I/usr/local/include -DUSE_PROJ
-DUSE_STATS -fpic -shared -Wl,-soname,libpostgis.so.0 postgis_debug.o
postgis_ops.o postgis_fn.o postgis_inout.o postgis_proj.o
postgis_chip.o postgis_transform.o postgis_gist_72.o postgis_estimate.o
postgis_geos.o postgis_geos_wrapper.o postgis_algo.o -L../../src/port
-L../../src/port -lstdc++ -L/usr/local/lib -lgeos -L/usr/local/lib
-lproj -Wl,-rpath,/usr/local/pgsql/lib -o libpostgis.so.0.8
/usr/lib/gcc-lib/ia64-suse-linux/3.2/../../../../ia64-suse-linux/bin/
ld: postgis_geos_wrapper.o: @gprel relocation against dynamic symbol
geomFactory
W/o GEOS I got the PostGIS to compile and install successfully. Would
you have some clues on what to do next?
Thanks,
Pavel Velikhov
San Diego Supercomputer Center
