[postgis-users] install help- postgis
    arun at activeengineer.com
    Wed Jan 28 18:19:06 PST 2004
When I installed postgresql, I did using the source but did not remove the
RPM's. Are you suggesting to the RPM's for postgresql and re-compile from
source? Thanks for your help.
Arun
Quoting "Gerry Creager (N5JXS)" <gerry.creager at tamu.edu>:
> we have found that the RPMs for PostGres on Redhat often leave
> "something to be desired."  So, we remove the RPM, download the source
> and recompile.  Gives you the entire source tree in a known, stable
> location, without losing any of those pesky little things Redhat might
> think you won't ever need...
> arun at activeengineer.com wrote:
> > I am trying to install postgis on a redhat server. I did these ( as per
> > instructions on PostGIS site):
> > cd contrib
> > gunzip postgis-0.8.0.tar.gz
> > tar xvf postgis-0.8.0.tar
> > cd postgis-0.8.0
> > make
> > Now, make gives the following error:
> > #make:*** Norule to make target `../../configure', needed by
> > `../../config.status'. Stop.
> > I tried both versions .8.0 and 0.8.1
> > Can any one point me where am I going wrong?
> > Arun
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
> Gerry Creager -- gerry.creager at tamu.edu
> Network Engineering -- AATLT, Texas A&M University
> Office: 979.458.4020  FAX: 979.847.8578
> Cell: 979.229.5301    Pager: 979.228.0173
