[postgis-users] shp2pgsql not loading in 0.8.2
strk
strk at keybit.net
Thu Jan 29 09:11:37 PST 2004
carrolls wrote:
> Hi strk,
> Sorry for the late response. I edited shp2pgsql.c to take a schema
> arguement and made the needed changes to accomadate the schema arguement.
> So I guess the answer to your question is yes. Thanks for making
> Add/DropGeometryColumn handle schemas.
Would you share your changes in shp2pgsql.c ?
I did not continue with it because stuck with the amount of if/then
blocks reached with identifiers quoting, schema support and similar...
I was reasoning about re-organizing most of the code but haven't find
the time yet. I was thinking about reducing the lines printing the
insert part :)
--strk;
> Seamus
> On Sat, 17 Jan 2004, strk wrote:
> > carrolls wrote:
> > > Looks good,
> > > I have tried importing in the table and I think it now works without
> > > error.
> > Did you get to create the geotable in the schema of your choice ?
> > --strk;
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
