[postgis-users] shp2pgsql not loading in 0.8.2
Seamus Thomas Carroll carrolls at cpsc.ucalgary.ca
Thu Jan 29 13:44:31 PST 2004
I ran the diff between my shp2pgsql and the previous shp2pgsql (from cvs).
I think i have tested most everything in my personal use except the -D
option.
Seamus
On Thu, 29 Jan 2004, strk wrote:
> carrolls wrote:
> > Hi strk,
> > Sorry for the late response.  I edited shp2pgsql.c to take a schema
> > arguement and made the needed changes to accomadate the schema arguement.
> > So I guess the answer to your question is yes.  Thanks for making
> > Add/DropGeometryColumn handle schemas.
> Would you share your changes in shp2pgsql.c ?
> I did not continue with it because stuck with the amount of if/then
> blocks reached with identifiers quoting, schema support and similar...
> I was reasoning about re-organizing most of the code but haven't find
> the time yet. I was thinking about reducing the lines printing the
> insert part :)
> --strk;
> > Seamus
> > On Sat, 17 Jan 2004, strk wrote:
> > > carrolls wrote:
> > > > Looks good,
> > > > I have tried importing in the table and I think it now works without
> > > > error.
> > > Did you get to create the geotable in the schema of your choice ?
> > > --strk;
> > > _______________________________________________
> > > postgis-users mailing list
> > > postgis-users at postgis.refractions.net
> > > http://postgis.refractions.net/mailman/listinfo/postgis-users
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20040129/daad4474/attachment.txt>
