[postgis-users] shp2pgsql not loading in 0.8.2
strk strk at keybit.net
Fri Jan 30 03:18:40 PST 2004
Just a quick look:
-- printf("\nInsert into \"%s.%s\" %s
Cannot be right, since MySchema.MyTable should be written
"MySchema"."MyTable" and not "MySchema.MyTable" which would be
interpreted as the name of a single table.
Moreover we don't want to miss support for pre-schema installations,
so schema usage should be activated only when provided.
.. I still think the best way is just setting the searc_path before
   sourcing the output of shp2pgsql for now ...
--strk;
carrolls wrote:
> Hi,
> I ran the diff between my shp2pgsql and the previous shp2pgsql (from cvs).
> I think i have tested most everything in my personal use except the -D
> option.
> Seamus
> On Thu, 29 Jan 2004, strk wrote:
> > carrolls wrote:
> > > Hi strk,
> > > Sorry for the late response.  I edited shp2pgsql.c to take a schema
> > > arguement and made the needed changes to accomadate the schema arguement.
> > > So I guess the answer to your question is yes.  Thanks for making
> > > Add/DropGeometryColumn handle schemas.
> > Would you share your changes in shp2pgsql.c ?
> > I did not continue with it because stuck with the amount of if/then
> > blocks reached with identifiers quoting, schema support and similar...
> > I was reasoning about re-organizing most of the code but haven't find
> > the time yet. I was thinking about reducing the lines printing the
> > insert part :)
> > --strk;
> > > Seamus
> > > On Sat, 17 Jan 2004, strk wrote:
> > > > carrolls wrote:
> > > > > Looks good,
> > > > > I have tried importing in the table and I think it now works without
> > > > > error.
> > > > Did you get to create the geotable in the schema of your choice ?
> > > > --strk;
> > > > _______________________________________________
> > > > postgis-users mailing list
> > > > postgis-users at postgis.refractions.net
> > > > http://postgis.refractions.net/mailman/listinfo/postgis-users
Content-Description: diff file
> 132c132
> < int ring_check(SHPObject* obj, char *schema, char *table, char *sr_id, int rings,
> > int ring_check(SHPObject* obj, char *table, char *sr_id, int rings,
> 282c282
> < int ring_check(SHPObject* obj, char *schema, char *table, char *sr_id, int rings,DBFHandle hDBFHandle){
> > int ring_check(SHPObject* obj, char *table, char *sr_id, int rings,DBFHandle hDBFHandle){
> 428c428
> < 				printf("\nInsert into \"%s.%s\" %s values(",schema,table,col_names);
> > 				printf("\nInsert into \"%s\" %s values(",table,col_names);
> 430c430
> < 				printf("\nInsert into \"%s.%s\" %s values('%i',",schema,table,col_names,rings);
> > 				printf("\nInsert into \"%s\" %s values('%i',",table,col_names,rings);
> 434c434
> < 				printf("\nInsert into %s.%s %s values(",schema,table,col_names);
> > 				printf("\nInsert into %s %s values(",table,col_names);
> 436c436
> < 				printf("\nInsert into %s.%s %s values('%i',",schema,table,col_names,rings);
> > 				printf("\nInsert into %s %s values('%i',",table,col_names,rings);
> 596c596
> < 	char  *sr_id,*shp_file,*schema = "public",*table;
> > 	char  *sr_id,*shp_file,*table;
> 649c649
> < 	for ( ; optind < ARGC; optind++){
> 652c652
> < 		}else if( curindex == 1 ){
> > 		}else if(curindex == 1){
> 654,655d653
> < 		}else if(curindex == 2){
> < 			schema = ARGV[optind];
> 671c669
> < 		printf("USAGE: shp2pgsql [<options>] <shapefile name> <table name> [<schema name>]\n");
> > 		printf("USAGE: shp2pgsql [<options>] <shapefile name> <table name>\n");
> 688d685
> < 		printf("\n<schema> defaults to public.\n");
> 704c701
> < 		printf("select DropGeometryColumn('%s','%s','the_geom');", schema, table);
> > 		printf("select DropGeometryColumn('','%s','the_geom');", table);
> 706c703
> < 			printf("\ndrop table \"%s.%s\";\n",schema,table);
> > 			printf("\ndrop table \"%s\";\n",table);
> 708c705
> < 			printf("\ndrop table %s.%s;\n",schema,table);
> > 			printf("\ndrop table %s;\n",table);
> 780c777
> < 			printf("CREATE TABLE \"%s.%s\" (gid serial", schema, table);
> > 			printf("CREATE TABLE \"%s\" (gid serial", table);
> 782c779
> < 			printf("CREATE TABLE %s.%s (gid serial", schema, table);
> > 			printf("CREATE TABLE %s (gid serial", table);
> 850c847
> < 		printf("select AddGeometryColumn('%s','%s','the_geom','%s',",schema,table,sr_id);
> > 		printf("select AddGeometryColumn('','%s','the_geom','%s',",table,sr_id);
> 880c877
> < 			printf("COPY \"%s.%s\" %s FROM stdin;\n",schema,table, col_names);
> > 			printf("COPY \"%s\" %s FROM stdin;\n",table, col_names);
> 935c932
> < 			tot_rings = ring_check(obj,schema,table,sr_id,tot_rings,hDBFHandle);
> > 			tot_rings = ring_check(obj,table,sr_id,tot_rings,hDBFHandle);
> 972c969
> < 						printf("insert into \"%s.%s\" %s values (",schema,table,col_names);
> > 						printf("insert into \"%s\" %s values (",table,col_names);
> 974c971
> < 						printf("insert into \"%s.%s\" %s values ('%i',",schema,table,col_names,j);
> > 						printf("insert into \"%s\" %s values ('%i',",table,col_names,j);
> 978c975
> < 						printf("insert into %s.%s %s values (",schema,table,col_names);
> > 						printf("insert into %s %s values (",table,col_names);
> 980c977
> < 						printf("insert into %s.%s %s values ('%i',",schema,table,col_names,j);
> > 						printf("insert into %s %s values ('%i',",table,col_names,j);
> 1050c1047
> < 						printf("insert into \"%s.%s\" %s values(",schema,table,col_names);
> > 						printf("insert into \"%s\" %s values(",table,col_names);
> 1052c1049
> < 						printf("insert into \"%s.%s\" %s values('%i',",schema,table,col_names,j);
> > 						printf("insert into \"%s\" %s values('%i',",table,col_names,j);
> 1056c1053
> < 						printf("insert into %s.%s %s values(",schema,table,col_names);
> > 						printf("insert into %s %s values(",table,col_names);
> 1058c1055
> < 						printf("insert into %s.%s %s values('%i',",schema,table,col_names,j);
> > 						printf("insert into %s %s values('%i',",table,col_names,j);
> 1170c1167
> 1172c1169
> 1176c1173
> 1178c1175
> 1246c1243
> 1248c1245
> 1252c1249
> 1254c1251
> 1324c1321
> 1326c1323
> 1330c1327
> 1332c1329
> 1439c1436
> 1477c1474
> 1479c1476
> 1483c1480
> 1485c1482
> 1537c1534
> < 		printf("\nALTER TABLE ONLY %s.%s ADD CONSTRAINT %s_pkey PRIMARY KEY (gid);\n",schema,table,table);
> > 		printf("\nALTER TABLE ONLY %s ADD CONSTRAINT %s_pkey PRIMARY KEY (gid);\n",table,table);
> 1539c1536
> < 			printf("SELECT setval ('%s.%s_gid_seq', %i, true);\n", schema,table, j-1);
> > 			printf("SELECT setval ('%s_gid_seq', %i, true);\n", table, j-1);
