[postgis-users] postgis+zaurus 5500
Jonathan Giorgio Ghellere
jonathan at ecosconsult.com.br
Fri Jul 2 07:44:42 PDT 2004
Hello,
I've compiled postgresql+postgis+proj for a zaurus 5500 running openzaurus 3.
3.5 and used qgis in a x86 machine to connect to the database in the zaurus.
The database was created using the http://postgis.refractions.net/docs/c206.
html:
CREATE TABLE gtest ( ID int4, NAME varchar(20) );
SELECT AddGeometryColumn('dbname','gtest','geom',-1,'LINESTRING',2);
INSERT INTO gtest (ID, NAME, GEOM) VALUES (1, 'First Geometry',
GeometryFromText('LINESTRING(2 3,4 5,6 5,7 8)', -1));
Everything goes ok, but, when I use QGIS (http://qgis.org), to retrieve a
feature map it returns a blank screen. So, I debug QGIS in order to see how it
was selecting map and got something like this:
select oid,asbinary(geom,'NDR') as qgs_feature_geometry from gtest where geom
&& GeometryFromText('BOX3D( 1.529391 2.750000, 7.470609
8.250000)'::box3d,-1);
In psql that query line returns:
oid |
21265 |
010200000004000000000000400000000000000840000000000000104000000000000014400000
00000000184000000000000014400000000000001C40000000000000204000000000
(1 row)
Ok, this line did not show much, but take a look in the same query in a x86
machine:
oid |
19203 |
000200000004000000000000000000004000000000000008400000000000001040000000000000
1440000000000000184000000000000014400000000000001C400000000000002040
(1 row)
It looks like the bytes are swapped. Do anybody knows why it's happening ?
tks for the help.
http://www.ecosconsult.com.br
EcosConsult Planejamento Ltda
_________________________
Linux - uvscan antivirus
