[postgis-users] postgis+zaurus 5500
    strk
    strk at keybit.net
    Fri Jul  2 08:06:31 PDT 2004
It seems postgis is not able to correctly detect BYTE_ORDER
on zaurus. Please check BYTE_ORDER and the like defines
in postgis_fn.c. Also try to find out where does your system
define that (if it does) or a architectur specific header defined
that could be handled for the specific case.
--strk;
On Fri, Jul 02, 2004 at 11:44:42AM -0300, Jonathan Giorgio Ghellere wrote:
> Hello,
> I've compiled postgresql+postgis+proj for a zaurus 5500 running openzaurus 3.
> 3.5 and used qgis in a x86 machine to connect to the database in the zaurus.
> The database was created using the http://postgis.refractions.net/docs/c206.
> html:
> CREATE TABLE gtest ( ID int4, NAME varchar(20) );
> SELECT AddGeometryColumn('dbname','gtest','geom',-1,'LINESTRING',2);
> INSERT INTO gtest (ID, NAME, GEOM) VALUES (1, 'First Geometry',
> GeometryFromText('LINESTRING(2 3,4 5,6 5,7 8)', -1));
> Everything goes ok, but, when I use QGIS (http://qgis.org), to retrieve a
> feature map it returns a blank screen. So, I debug QGIS in order to see how it
> was selecting map and got something like this:
> select oid,asbinary(geom,'NDR') as qgs_feature_geometry from gtest where geom
> && GeometryFromText('BOX3D(        1.529391         2.750000,        7.470609
>        8.250000)'::box3d,-1);
> In psql that query line returns:
>   oid  |
>  21265 |
> 010200000004000000000000400000000000000840000000000000104000000000000014400000
> 00000000184000000000000014400000000000001C40000000000000204000000000
> (1 row)
> Ok, this line did not show much, but take a look in the same query in a x86
> machine:
>   oid  |
>  19203 |
> 000200000004000000000000000000004000000000000008400000000000001040000000000000
> 1440000000000000184000000000000014400000000000001C400000000000002040
> (1 row)
> It looks like the bytes are swapped. Do anybody knows why it's happening ?
> tks for the help.
> http://www.ecosconsult.com.br
> EcosConsult Planejamento Ltda
> _________________________
> Linux - uvscan antivirus
> postgis-users mailing list
