[postgis-users] jdbc, bytea for the write side
David Blasby dblasby at gmail.com
Sun Jul 4 20:22:31 PDT 2004
ByteA is binary compatible with the postgis type, so you should just
be able to create a "binary compatible" 'NULL' cast for it.
I think something like "CREATE CAST (BYTEA AS
WKB)   WITHOUT FUNCTION AS IMPLICIT ;" should do the trick.
This is only available in recent postgresql versions.
You can do it in older versions easily, too.
Unfortunately, I'm no longer working at Refractions and I havent got a
system setup at home yet; I'm unable to test.
I believe you can (as funny as it sounds), use the "WKBtoBYTEA"
function since its a do-nothing function.
CREATE FUNCTION wkb(bytea)
       RETURNS geometry
       AS '@MODULE_FILENAME@','WKBtoBYTEA'
       LANGUAGE 'C' WITH (iscachable,isstrict);
So instead of using "bytea2wkb()" you can use "wkb(<bytea>)".
If this works, have strk commit the change.
Have you checked to see whats actually being sent between geotools and
Postgis?  If I remember the SQL standard, bytea is sent as strings
like '0001001001000111001' - you could be sending 8* as much data as
you're expecting.  (This is assuming a text, NOT binary, cursor).
dave
