[postgis-users] POINT conversion
Rafael Vidal Aroca
rafael at 3wt.com.br
Thu Jul 8 15:11:21 PDT 2004
Thanks!
Using x() and y() solved my problem, and i also found another
possible solution using postgis classes for java, where we can make an
instance of a point from the database and use getX and getY methods.
Rafael.
Paul Ramsey wrote:
> You're most of the way there.
> Use the X() and Y() functions to extract the ordinates back out of
> your transformed point, and then write a reverse function to do from
> DD.DDDD to DDMM.SS format.
> Paul
> Rafael Vidal Aroca wrote:
>> Hello, i have 2 questions related to the POINT structure. One is
>> about what i did, and another about what i'll do :-)
>> The problem:
>> I have a table with 2 fields that keep historic GPS positions
>> (latitude and longitude). This fields are stored in WGS84 format,
>> DDMM.SS.
>> I need this data in SAD69/UTM format, but to convert the data i
>> need these values to be in DD.MMSS
>> What i did:
>> I created a postgresql function that converts DDMM.SS to DD.MMSS
>> and called this function inside a select with transform, and ok, i
>> got the data in the format i need!
>> But is this the best way to do it? Or is there another way of
>> doing this that i am not aware of?
>> What i'll do:
>> The data i got is correct, but unsable, because the output is like:
>> SRID=X, POINT(xxxxx yyyyy)
>> but this is not of any help for me, because i need these two
>> valeus in separeted fields of a table or view...or am i doing
>> something wrong? Is there another way of dealing with these valeus? I
>> have a servlet that reads a table and generates a xml output...
>> thanks
>> Rafael.
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
