[postgis-users] POINT conversion
Paul Ramsey pramsey at refractions.net
Wed Jul 7 08:29:06 PDT 2004
You're most of the way there.
Use the X() and Y() functions to extract the ordinates back out of your
transformed point, and then write a reverse function to do from DD.DDDD
to DDMM.SS format.
Paul
Rafael Vidal Aroca wrote:
> 	Hello, i have 2 questions related to the POINT structure. One is about what i did, and another about what i'll do :-)
> 	The problem:
> 	I have a table with 2 fields that keep historic GPS positions (latitude and longitude). This fields are stored in WGS84 format, DDMM.SS.
> 	I need this data in SAD69/UTM format, but to convert the data i need these values to be in DD.MMSS
> 	What i did:
> 	I created a postgresql function that converts DDMM.SS to DD.MMSS and called this function inside a select with transform, and ok, i got the data in the format i need!
> 	But is this the best way to do it? Or is there another way of doing this that i am not aware of?
> 	What i'll do:
> 	The data i got is correct, but unsable, because the output is like:
> 	SRID=X, POINT(xxxxx yyyyy)
> 	but this is not of any help for me, because i need these two valeus in separeted fields of a table or view...or am i doing something wrong? Is there another way of dealing with these valeus? I have a servlet that reads a table and generates a xml output...
> 	thanks
> 	Rafael.
> postgis-users mailing list
