[postgis-users] please NEED help....
strk strk at keybit.net
Tue Jul 13 00:42:44 PDT 2004
It's a missing support for new postgresql in the postgis connector.
Old postgresql automatically closed portals on end of transaction,
while new one do not. Dunno why that connector is not fixed yet.
--strk;
On Tue, Jul 13, 2004 at 09:23:22AM +0200, Sébastien DUBOIS wrote:
> i'm quite sad no answer to my old post :
> http://postgis.refractions.net/pipermail/postgis-users/2004-July/005170.html
> (let's see a the end of the message)
> i'm quite sure someone of you have to solve in the past this topic issue.
> when querying by rectangle multi points i got the error:
> Warning: [MapServer Error]: msPOSTGISLayerGetShape(): Error executing POSTGIS
> SQL statement (in FETCH ALL): DECLARE mycursor BINARY CURSOR FOR SELECT
> the_geom::text,asbinary(force_collection(force_2d(the_geom)),'NDR') from
> clientspostgis WHERE oid = 19621 -ERROR: cursor "mycursor" already exists
> More Help:
> Error with POSTGIS data variable. You specified ''.
> Standard ways of specifiying are :
> (1) 'geometry_column from geometry_table'
> (2) 'geometry_column from (<sub query>) as foo using unique <column name> using
> SRID=<srid#>'
> Make sure you put in the 'using unique <column name>' and 'using SRID=#' clauses
> in.
> LET'S SEE ALL MY [LONG] POST:
> I'd imported in the Gmap soft (from dmsolutions phpmapscript+mapserver+rosa)
> a postgis layer build with shp2pgsql
> >createdb montelimarpostgis
> >createlang plpgsql montelimarpostgis
> >psql montelimarpostgis < /home/postgre/postgis.sql
> >psql montelimarpostgis < /home/postgre/spatial_ref_sys.sql
> >shp2pgsql -D /var/www/html/workshop/data/Clients.shp clientspostgis
> montelimarpostgis | psql montelimarpostgis
> then
> montelimarpostgis=# \d clientspostgis
>                                   Table "public.clientspostgis"
>    Column   |       Type        |                            Modifiers
>  gid        | integer           | not null default
> extval('public.clientspostgis_gid_seq'::text)
>  adresse    | character varying |
>  departemen | bigint            |
>  x_adresse  | numeric           |
>  y_adresse  | numeric           |
>  nom        | character varying |
>  prenom     | character varying |
>  tel_fixe   | character varying |
>  tel_mobile | character varying |
>  email      | character varying |
>  id_client  | character varying |
>  the_geom   | geometry          |
> Indexes:
>     "clientspostgis_pkey" primary key, btree (gid)
>     "clientspostgis_geom_idx" gist (the_geom)
> Check constraints:
>     "$1" CHECK (srid(the_geom) = -1)
>     "$2" CHECK (geometrytype(the_geom) = 'POINT'::text OR the_geom IS NULL)
> montelimarpostgis=# \d geometry_columns
>             Table "public.geometry_columns"
>  f_table_catalog   | character varying(256) | not null
>  f_table_schema    | character varying(256) | not null
>  f_table_name      | character varying(256) | not null
>  f_geometry_column | character varying(256) | not null
>  coord_dimension   | integer                | not null
>  srid              | integer                | not null
>  type              | character varying(30)  | not null
>  attrelid          | oid                    |
>  varattnum         | integer                |
>  stats             | histogram2d            |
> Indexes:
>     "geometry_columns_pk" primary key, btree (f_table_catalog, f_table_schema,
> f_table_name, f_geometry_column)
> my layer in my .map looks like this :
> LAYER
>   NAME montelimarpostgis
>   METADATA
>     "DESCRIPTION"   "Clients/Postgis"
>     "RESULT_FIELDS" "ADRESSE DEPARTEMEN X_ADRESSE Y_ADRESSE NOM PRENOM TEL_FIXE
> TEL_MOBILE EMAIL ID_CLIENT"
>   END
>   TYPE POINT
>   STATUS ON
>   CONNECTIONTYPE postgis
>   CONNECTION "host=localhost dbname=montelimarpostgis user=postgre
> password=postgre"
>   DATA 'the_geom from clientspostgis using unique oid using SRID=-1 '
> #'the_geom from (select oid,the_geom from clientspostgis) as foo'
> #or
> #the_geom from clientspostgis using unique oid using SRID=-1'
> #->ok but rectangle select bug
> #"select f_geometry_column,type from geometry_columns where f_table_name like
> "clientspostgis""
>   LabelItem "the_geom"  #ce que l'on souhaite afficher comme attribut parmi
> RESULT_FIELDS à coté des points
>   CLASSITEM "the_geom"
>   CLASS
>     EXPRESSION "1"
>     TEMPLATE "ttt_query.html"
>     SYMBOL 2
>     SIZE 8
>     NAME "clientspostgis"
>     LABEL
>       COLOR  255 0 0
>       FONT fritqat-italic
>       TYPE truetype
>  SIZE 8
>       POSITION AUTO
>       PARTIALS FALSE
>       OUTLINECOLOR 255 255 255
>     END
>     COLOR 0 0 0
>   END
>   CLASS
>     EXPRESSION /2|3/
>     SYMBOL 7
>     SIZE 6
>     NAME "clientpostgis"
>     LABEL
>     COLOR  0 0 0  #couleur affichage legende point
>      FONT fritqat
>      TYPE truetype
>      SIZE 8
>      POSITION AUTO
>      PARTIALS FALSE
>     END
>     COLOR 0 0 0
>   END
>   TOLERANCE 5
> END # Layer
> With this code, i succeed in displaying my point (with label POINT(X,Y))
> BUT
> *when i make a query on ONLY ONE POINT I can't display the attributes of my
> original shapefile (so the colums of clientspostgis)
> My metadata is correct ...
> No error when i query only no display
> *when i make a query on MULTI points: ERROR
> More Help:
> SRID=<srid#>'
> clauses
> in.
> I've read that sometimes in old version the multipoint query error is due to
> postgis not closed at the end of a requet but i have the last version of
> mapserv and postgis ...
> CAN SOMEONE GIVE ME SOME HELP??
> Sébastien DUBOIS
> Ecole Généraliste d'Ingénieurs de Marseille (ex ESM2)
> 1024D/A1140BCB
> Empreinte de la clé = 1BC8 7E21 4DA7 13D5 1B5F  876F F719 2B7A A114 0BCB
> disponible sur www.keyserver.net
> This mail sent through IMP: http://horde.org/imp/
> postgis-users mailing list
