[postgis-users] please NEED help....
Sébastien DUBOIS
sebastien.dubois at esm2.imt-mrs.fr
Tue Jul 13 00:23:22 PDT 2004
i'm quite sad no answer to my old post :
http://postgis.refractions.net/pipermail/postgis-users/2004-July/005170.html
(let's see a the end of the message)
i'm quite sure someone of you have to solve in the past this topic issue.
when querying by rectangle multi points i got the error:
Warning: [MapServer Error]: msPOSTGISLayerGetShape(): Error executing POSTGIS
SQL statement (in FETCH ALL): DECLARE mycursor BINARY CURSOR FOR SELECT
the_geom::text,asbinary(force_collection(force_2d(the_geom)),'NDR') from
clientspostgis WHERE oid = 19621 -ERROR: cursor "mycursor" already exists
More Help:
Error with POSTGIS data variable. You specified ''.
Standard ways of specifiying are :
(1) 'geometry_column from geometry_table'
(2) 'geometry_column from (<sub query>) as foo using unique <column name> using
SRID=<srid#>'
Make sure you put in the 'using unique <column name>' and 'using SRID=#' clauses
in.
LET'S SEE ALL MY [LONG] POST:
I'd imported in the Gmap soft (from dmsolutions phpmapscript+mapserver+rosa)
a postgis layer build with shp2pgsql
>createdb montelimarpostgis
>createlang plpgsql montelimarpostgis
>psql montelimarpostgis < /home/postgre/postgis.sql
>psql montelimarpostgis < /home/postgre/spatial_ref_sys.sql
>shp2pgsql -D /var/www/html/workshop/data/Clients.shp clientspostgis
montelimarpostgis | psql montelimarpostgis
then
montelimarpostgis=# \d clientspostgis
Table "public.clientspostgis"
Column | Type | Modifiers
gid | integer | not null default
extval('public.clientspostgis_gid_seq'::text)
adresse | character varying |
departemen | bigint |
x_adresse | numeric |
y_adresse | numeric |
nom | character varying |
prenom | character varying |
tel_fixe | character varying |
tel_mobile | character varying |
email | character varying |
id_client | character varying |
the_geom | geometry |
Indexes:
"clientspostgis_pkey" primary key, btree (gid)
"clientspostgis_geom_idx" gist (the_geom)
Check constraints:
"$1" CHECK (srid(the_geom) = -1)
"$2" CHECK (geometrytype(the_geom) = 'POINT'::text OR the_geom IS NULL)
montelimarpostgis=# \d geometry_columns
Table "public.geometry_columns"
f_table_catalog | character varying(256) | not null
f_table_schema | character varying(256) | not null
f_table_name | character varying(256) | not null
f_geometry_column | character varying(256) | not null
coord_dimension | integer | not null
srid | integer | not null
type | character varying(30) | not null
attrelid | oid |
varattnum | integer |
stats | histogram2d |
Indexes:
"geometry_columns_pk" primary key, btree (f_table_catalog, f_table_schema,
f_table_name, f_geometry_column)
my layer in my .map looks like this :
LAYER
NAME montelimarpostgis
METADATA
"DESCRIPTION" "Clients/Postgis"
"RESULT_FIELDS" "ADRESSE DEPARTEMEN X_ADRESSE Y_ADRESSE NOM PRENOM TEL_FIXE
TEL_MOBILE EMAIL ID_CLIENT"
END
TYPE POINT
STATUS ON
CONNECTIONTYPE postgis
CONNECTION "host=localhost dbname=montelimarpostgis user=postgre
password=postgre"
DATA 'the_geom from clientspostgis using unique oid using SRID=-1 '
#'the_geom from (select oid,the_geom from clientspostgis) as foo'
#or
#the_geom from clientspostgis using unique oid using SRID=-1'
#->ok but rectangle select bug
#"select f_geometry_column,type from geometry_columns where f_table_name like
"clientspostgis""
LabelItem "the_geom" #ce que l'on souhaite afficher comme attribut parmi
RESULT_FIELDS à coté des points
CLASSITEM "the_geom"
CLASS
EXPRESSION "1"
TEMPLATE "ttt_query.html"
SYMBOL 2
SIZE 8
NAME "clientspostgis"
LABEL
COLOR 255 0 0
FONT fritqat-italic
TYPE truetype
SIZE 8
POSITION AUTO
PARTIALS FALSE
OUTLINECOLOR 255 255 255
END
COLOR 0 0 0
END
CLASS
EXPRESSION /2|3/
SYMBOL 7
SIZE 6
NAME "clientpostgis"
LABEL
COLOR 0 0 0 #couleur affichage legende point
FONT fritqat
TYPE truetype
SIZE 8
POSITION AUTO
PARTIALS FALSE
END
COLOR 0 0 0
END
TOLERANCE 5
END # Layer
With this code, i succeed in displaying my point (with label POINT(X,Y))
BUT
*when i make a query on ONLY ONE POINT I can't display the attributes of my
original shapefile (so the colums of clientspostgis)
My metadata is correct ...
No error when i query only no display
*when i make a query on MULTI points: ERROR
More Help:
SRID=<srid#>'
clauses
in.
I've read that sometimes in old version the multipoint query error is due to
postgis not closed at the end of a requet but i have the last version of
mapserv and postgis ...
CAN SOMEONE GIVE ME SOME HELP??
Sébastien DUBOIS
Ecole Généraliste d'Ingénieurs de Marseille (ex ESM2)
1024D/A1140BCB
Empreinte de la clé = 1BC8 7E21 4DA7 13D5 1B5F 876F F719 2B7A A114 0BCB
disponible sur www.keyserver.net
This mail sent through IMP: http://horde.org/imp/
