[postgis-users] Make error: transform
Paul Ramsey pramsey at refractions.net
Wed Jul 14 09:33:55 PDT 2004
In general, you need to include more lines of context when quoting an
error. However, I will take an educated guess and say that while you
have not installed Proj4 on your system, your Makefile indicates that
PostGIS should USE_PROJ. Either install Proj4, or turn USE_PROJ to 0.
Paul
Bato Pure wrote:
> Hi all,
> OS: Redhat Linux 9
> PostgreSQL: 7.4.3
> PostGIS: 0.8.2
> The problem: when give make command it returns
> make: *** [postgis_transform.o] Error 1
> at the end.
> Is there someone who met this prob?
> Let me know your solution.
> Bato
