[postgis-users] installation (last step) problems
Marie-Lise VAUTIER
vautier at ensg.ign.fr
Thu Jul 15 04:25:01 PDT 2004
Hello,
I know that it is a very current problem, but I have a problem with the last
step of the installation of postgis, that is to say, when I enter spql -d mydb
-f postgis.sql.
I have installed geos and proj4, because I already had problems without them.
geos has been installed with the default ./configure and proj4 with ./configure
--prefix=/usr/local/proj4.
I get the following error message:
[postgres at localhost postgres]$ psql -d mydb -f
/usr/local/pgsql/share/contrib/postgis.sql
BEGIN
message
PL/PgSQL is installed.
(1 row)
NOTICE: type "histogram2d" is not yet defined
DETAIL: Creating a shell type definition.
ERROR: could not load library "/usr/local/pgsql/lib/libpostgis.so.0.8":
libgeos.so.1: cannot open shared obj
ect file: No such file or directory
psql:/usr/local/pgsql/share/contrib/postgis.sql:44: NOTICE: type "histogram2d"
is not yet defined
psql:/usr/local/pgsql/share/contrib/postgis.sql:44: ERROR: could not load
ostgis.so.0.8": libgeos.so.1: cannot open shared object file: No such file or
directory
ERROR: current transaction is aborted, commands ignored until end of
transaction block
psql:/usr/local/pgsql/share/contrib/postgis.sql:49: ERROR: current transaction
until end of transaction block
libgeos.so.1 is in /usr/local/lib.
I have not "linked postgresql against the standard c++ library", as described in
the documentation, because I don't know exactly where to write this line. Is it
the reason why it doesn't work?
Thank you for your help, Marie-Lise.
