[postgis-users] RE: Postgresql installation problems
Swaminathan, Gayathri
gayathri at ou.edu
Thu Jul 15 06:18:44 PDT 2004
Hi:
As per Mark's suggestions I unregistered old versions of libpq.dll and did the following:
0) Connected to template1 through psql
1) created my new db using CREATE DATABASE athena LOCATION <path to data>
2) Createlang plpgsql athena
3) Ran the postgis.sql from share/contrib...
Works like a charm!Thanks mark.
And instead of PGAdmin, found this http://www.ems-hitech.com/pgmanager/download.phtml
That works without giving the tablespace error.
Gayathri
> -----Original Message-----
> From: Mark Cave-Ayland [mailto:m.cave-ayland at webbased.co.uk]
> Sent: Thursday, July 15, 2004 3:30 AM
> To: Swaminathan, Gayathri
> Cc: postgis-users at postgis.refractions.net
> Subject: RE: Postgresql installation problems
> > From: postgis-users-bounces at postgis.refractions.net
> > [mailto:postgis-users-bounces at postgis.refractions.net] On
> > Behalf Of Swaminathan, Gayathri
> > Sent: 14 July 2004 22:42
> > To: m.cave-ayland at webbased.co.uk
> > Subject: [postgis-users] Postgresql installation problems
> > Hi Mark:
> > I downloaded the binary from the url in the email below. I am
> > sucessfully able to configure and run postgresql but when I
> > try to connect through PGAdmin I seem to get pg_tablespace
> > not found error..
> > Another thing is am not able to run any SQL statements such
> > as CREATE DATABASE etc., with the supplied psql.exe
> > Any help or pointers will be very useful
> > Gayathri
> Hi Gayathri,
> The development snapshot was produced before the patch for
> tablespaces was applied to PostgreSQL 7.5 and so I'm afraid
> you'll have to use an updated snapshot if you wish to use
> pgAdmin :(. psql.exe should work fine without any problems though.
> I'm surprised you can't run any commands with the supplied
> psql.exe; the only thing I can think of is that you already
> have another libpq.dll on your PC but I can't tell more
> without knowing the exact errors you are getting. A quick
> solution for this would be to change the PATH in env.bat so
> the snapshot directories are listed first, e.g.
> set PATH=C:\pgsql75win\lib;C:\pgsql75win\bin;%PATH%
> If you then run a new version of env.bat, psql.exe should
> spring into life.
> For the information of people on the list, the reason the
> snapshot hasn't been updated is that firstly it's purpose was
> to make sure that we could run PostGIS under Windows/PG7.5
> when it is released, and secondly there are some very large
> patches currently being applied (like
> tablespaces) which mean that CVS is tending to be very
> unstable. The current plan is to update the snapshot when 7.5
> enters beta when hopefully everything has been stabilised and
> then it should just be bugfixes. Stay tuned....
> Kind regards,
> Mark.
> Mark Cave-Ayland
> Webbased Ltd.
> Tamar Science Park
> Derriford
> Plymouth
> PL6 8BX
> England
> Tel: +44 (0)1752 764445
> Fax: +44 (0)1752 764446
> This email and any attachments are confidential to the
> intended recipient and may also be privileged. If you are not
> the intended recipient please delete it from your system and
> notify the sender. You should not copy it or use it for any
> purpose nor disclose or distribute its contents to any other person.
