[postgis-users] Documentation lacking & AddGeometryColumn schema_name vs db_name
Boyce, Greg
GBoyce at NRCan.gc.ca
Wed Jul 21 12:47:17 PDT 2004
And if I might add, the documentation has problems, and is skimpy
in many areas:
1 What version of PostGIS does the online docs correspond to?
2 There's no search function in the online docs
3 There are very few or no examples in the "OpenGIS Functions"
and "Other Functions" sections.
4 The OpenGIS function, SetSRID, is missing the SRID in the
definition.
5 Conflicting information on the AddGeometryColumn function. Is
it <db_name> or <schema_name>?
Chapter 4. Creating a spatial table:
http://postgis.refractions.net/docs/x321.html#AEN391
says
AddGeometryColumn(<db_name>, <table_name>, <column_name>, ...
SELECT AddGeometryColumn('roads_db', 'roads_geom', 'geom', ...
Yet in Chapter 5. -- OpenGIS Functions:
http://postgis.refractions.net/docs/c673.html
it says
AddGeometryColumn(<schema_name>, <table_name>, <column_name>, ...
(What do mean by saying that schema_name is a table schema?)
The example given in the recent MUM presentation on Mapserver &
PostGIS uses [dbname].
6 I've a database called "magdb". I add the geometry column:
SELECT AddGeometryColumn('magdb', 'surveys2', 'boundary', -1,
'POLYGON', 2);
and it gives an Notice message:
NOTICE: Invalid schema name - using current_schema()
CONTEXT: PL/pgSQL function "addgeometrycolumn" line 4 at select
into variables
addgeometrycolumn
The geometry_columns table contains (note the "public" not "magdb"):
f_table_catalog | f_table_schema | f_table_name | f_geometry_column
| coord_dimension | srid | type | attrelid | varattnum | stats
| public | surveys2 | boundary |
2 | -1 | POLYGON | 299809 | 3 |
A DropGeometryColumn on "magdb" of course doesn't work!
SELECT DropGeometryColumn('magdb', 'surveys', 'boundary27');
What's wrong? (I'm using PostgreSQL 7.4.3 and PostGIS 0.8.2)
Many thanks,
Greg Boyce
___________________________________________________
Regional Geophysics section / Section de la géophysique régionale
Geological Survey of Canada / Commission Géologique du Canada
Natural Resources Canada / Ressources naturelles Canada
Government of Canada / Gouvernement du Canada
