[postgis-users] Documentation lacking & AddGeometryColumn schema_name vs db_name
David TECHER
davidtecher at yahoo.fr
Thu Jul 22 04:11:19 PDT 2004
--- "Boyce, Greg" <GBoyce at NRCan.gc.ca> a écrit : > And
if I might add, the documentation has problems,
> and is skimpy
> in many areas:
> 1 What version of PostGIS does the online docs
> correspond to?
0.8.2 : Paul ramsey made the update few weeks ago
> 2 There's no search function in the online docs
just instal pgadmin III, you will see every functions
that you need but just the function's name
> 3 There are very few or no examples in the "OpenGIS
> Functions"
> and "Other Functions" sections.
Postgis distribution came with few examples at
postgis-0.8.2/examples/ogc_test_suite that you can see
at http://svg.cc/pg/ogc in SVG done by Klaus Foerster
> 4 The OpenGIS function, SetSRID, is missing the SRID
> in the
> definition.
> 5 Conflicting information on the AddGeometryColumn
> function. Is
> it <db_name> or <schema_name>?
> Chapter 4. Creating a spatial table:
> http://postgis.refractions.net/docs/x321.html#AEN391
> says
> AddGeometryColumn(<db_name>, <table_name>,
> <column_name>, ...
> SELECT AddGeometryColumn('roads_db', 'roads_geom',
> 'geom', ...
> Yet in Chapter 5. -- OpenGIS Functions:
> http://postgis.refractions.net/docs/c673.html
> it says
> AddGeometryColumn(<schema_name>, <table_name>,
> <column_name>, ...
> (What do mean by saying that schema_name is a
> table schema?)
> The example given in the recent MUM presentation
> on Mapserver &
> PostGIS uses [dbname].
> 6 I've a database called "magdb". I add the
> geometry column:
> SELECT AddGeometryColumn('magdb', 'surveys2',
> 'boundary', -1,
> 'POLYGON', 2);
> and it gives an Notice message:
> NOTICE: Invalid schema name - using
> current_schema()
> CONTEXT: PL/pgSQL function "addgeometrycolumn"
> line 4 at select
> into variables
> addgeometrycolumn
> The geometry_columns table contains (note the
> "public" not "magdb"):
> f_table_catalog | f_table_schema | f_table_name |
> f_geometry_column
> | coord_dimension | srid | type | attrelid |
> varattnum | stats
> | public | surveys2 |
> boundary |
> 2 | -1 | POLYGON | 299809 | 3 |
> A DropGeometryColumn on "magdb" of course doesn't
> work!
> SELECT DropGeometryColumn('magdb', 'surveys',
> 'boundary27');
> What's wrong? (I'm using PostgreSQL 7.4.3 and
> PostGIS 0.8.2)
> Many thanks,
> Greg Boyce
> ___________________________________________________
> Regional Geophysics section / Section de la
> géophysique régionale
> Geological Survey of Canada / Commission
> Géologique du Canada
> Natural Resources Canada / Ressources
> naturelles Canada
> Government of Canada / Gouvernement du
> Canada
> postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
Créez gratuitement votre Yahoo! Mail avec 100 Mo de stockage !
Créez votre Yahoo! Mail sur http://fr.benefits.yahoo.com/
Yahoo! Messenger: dialoguez instantanément avec vos amis. Téléchargez GRATUITEMENT sur http://fr.messenger.yahoo.com
