[postgis-users] Documentation lacking & AddGeometryColumn schema_name vs db_name
Paul Ramsey
pramsey at refractions.net
Thu Jul 22 08:31:46 PDT 2004
Hi Greg,
The postgis.xml file included in the source distribution is the parent
to the documentation html. If you want to update it I would happily
accept patches! It is in docbook XML.
Pau
Boyce, Greg wrote:
> And if I might add, the documentation has problems, and is skimpy
> in many areas:
> 1 What version of PostGIS does the online docs correspond to?
> 2 There's no search function in the online docs
> 3 There are very few or no examples in the "OpenGIS Functions"
> and "Other Functions" sections.
> 4 The OpenGIS function, SetSRID, is missing the SRID in the
> definition.
> 5 Conflicting information on the AddGeometryColumn function. Is
> it <db_name> or <schema_name>?
> Chapter 4. Creating a spatial table:
> http://postgis.refractions.net/docs/x321.html#AEN391
> says
> AddGeometryColumn(<db_name>, <table_name>, <column_name>, ...
> SELECT AddGeometryColumn('roads_db', 'roads_geom', 'geom', ...
> Yet in Chapter 5. -- OpenGIS Functions:
> http://postgis.refractions.net/docs/c673.html
> it says
> AddGeometryColumn(<schema_name>, <table_name>, <column_name>, ...
> (What do mean by saying that schema_name is a table schema?)
> The example given in the recent MUM presentation on Mapserver &
> PostGIS uses [dbname].
> 6 I've a database called "magdb". I add the geometry column:
> SELECT AddGeometryColumn('magdb', 'surveys2', 'boundary', -1,
> 'POLYGON', 2);
> and it gives an Notice message:
> NOTICE: Invalid schema name - using current_schema()
> CONTEXT: PL/pgSQL function "addgeometrycolumn" line 4 at select
> into variables
> addgeometrycolumn
> The geometry_columns table contains (note the "public" not "magdb"):
> f_table_catalog | f_table_schema | f_table_name | f_geometry_column
> | coord_dimension | srid | type | attrelid | varattnum | stats
> | public | surveys2 | boundary |
> 2 | -1 | POLYGON | 299809 | 3 |
> A DropGeometryColumn on "magdb" of course doesn't work!
> SELECT DropGeometryColumn('magdb', 'surveys', 'boundary27');
> What's wrong? (I'm using PostgreSQL 7.4.3 and PostGIS 0.8.2)
> Many thanks,
> Greg Boyce
> ___________________________________________________
> Regional Geophysics section / Section de la géophysique régionale
> Geological Survey of Canada / Commission Géologique du Canada
> Natural Resources Canada / Ressources naturelles Canada
> Government of Canada / Gouvernement du Canada
> postgis-users mailing list
