[postgis-users] query example??
    Tyler Mitchell
    tjmitchell at riverside.bc.ca
    Fri Jul 23 08:03:47 PDT 2004
You probably want to also use a Distance() function in your where clause,
in addition to &&.
...WHERE points.geom_column && units.geom_column
AND distance(points.geom_column, units.geom_column) = 0;
Of source, continue adding to the where clause to isolate the single unit
you are interested in.
Hope that helps.
Tyler
postgis-users-bounces at postgis.refractions.net wrote on 07/23/2004 07:40:47
AM:
> Hi
> I have a lot of points with coordinates in one shapefile and in another
> shapefile have a geological map right?; how can I do a query for
> instance: how many points are in a geological unit, I use && and ~= but
> the result is a box, but I need only the points that are inside one
> polygon(a geological unit) what I do??? what's the correct syntax???
> help
> regards
> postgis-users mailing list
