[postgis-users] query example??
AGT alejandrogalindo at tutopia.com
Fri Jul 23 08:51:20 PDT 2004
Hey man thanks
Only I need to do a query: how many points there are in a geological
unit (obviusly an irregular polygon, as in nature), what is the syntax;
Tried with your sentence and shows all the poinst, only need the points
INSIDE the irregular polygon how can I obtain that, give me patience
thanks
El vie, 23-07
-2004 a las 10:03, Tyler Mitchell escribió:
> You probably want to also use a Distance() function in your where clause,
> in addition to &&.
> ...WHERE points.geom_column && units.geom_column
> AND distance(points.geom_column, units.geom_column) = 0;
> Of source, continue adding to the where clause to isolate the single unit
> you are interested in.
> Hope that helps.
> Tyler
> postgis-users-bounces at postgis.refractions.net wrote on 07/23/2004 07:40:47
> AM:
> > Hi
> > I have a lot of points with coordinates in one shapefile and in another
> > shapefile have a geological map right?; how can I do a query for
> > instance: how many points are in a geological unit, I use && and ~= but
> > the result is a box, but I need only the points that are inside one
> > polygon(a geological unit) what I do??? what's the correct syntax???
> > help
> > regards
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
