[postgis-users] problems running postgis.sql
odain2 at mindspring.com odain2 at mindspring.com
Sun Jul 25 12:03:46 PDT 2004
I have downloaded and installed postgis and all the required dependencies.  I
downloaded the suse 9.1 rpms from:
http://postgis.refractions.net/rpms/suse/9.1/
and installed everything there including the version of postgresql provided
there on my suse 9.1 box.  Everything installed without a problem.  I then
set up a new database and ran createlang without a problem.  However, when I
try load the postgis.sql file I get the following errors:
oliver at marmaduke:contrib$ psql -U postgres -d GIS -f postgis.sql
BEGIN
        message
 PL/PgSQL is installed.
(1 row)
psql:postgis.sql:44: NOTICE:  type "histogram2d" is not yet defined
DETAIL:  Creating a shell type definition.
CREATE FUNCTION
psql:postgis.sql:49: NOTICE:  argument type histogram2d is only a shell
CREATE FUNCTION
CREATE TYPE
psql:postgis.sql:65: NOTICE:  type "box3d" is not yet defined
CREATE FUNCTION
psql:postgis.sql:70: NOTICE:  argument type box3d is only a shell
CREATE FUNCTION
CREATE TYPE
psql:postgis.sql:85: NOTICE:  type "spheroid" is not yet defined
CREATE FUNCTION
psql:postgis.sql:90: NOTICE:  argument type spheroid is only a shell
CREATE FUNCTION
CREATE TYPE
etc.
After reading some of the posts to this list I tried editing postgis.sql and
replacing all the $libdir instances with the full path to libpostgis.so.0.8.
That didn't help.  I also tried defining and exporting a shell variable
called $libdir whose value is the path to libpostgis, but again this didn't
help.  Any ideas???
Thanks,
Oliver
