[postgis-users] Very long time for a bbox/within query
Gregory S. Williamson
gsw at globexplorer.com
Sun Jul 25 13:34:59 PDT 2004
Hopeless.
I rewrote the query to pick up the FIPS boundry so there is no subselect in either the bounding box or within queries.
After waiting 6 hours with one CPU pegged I killed the process.
There is something badly wrong with postGIS if it can't process one county (complicated but a legitimate multipolygon -- Bradford Florida, FIPS 12007) and a within statement for data set (some 4.2 million rows) in 360 minutes of processing time.
The "within" operation is clearly the dog -- the bounding box query works blindingly fast.
All I need to is if there is any overlap between a county and any of the detail data. Apparently postGIS cannot tell me this.
Looks like we have to migrate back to Informix, which at least can produce answers.
Greg Williamson
DBA
GlobeXplorer LLC
-----Original Message-----
Sent: Tue 7/20/2004 2:42 PM
To: PostGIS Users Discussion
Cc:
Subject: Re: [postgis-users] Very long time for a bbox/within query
Instead of the sub-queries try putting in the actual geometries (run
the sub-queries in psql and copy-and-paste in the results). If it
runs fast, then its probably running the sub-query multiple times or
the type casting system is getting confused.
Next, I'd try removing the within() clause. If it runs fast, then
you're spending a lot of time inside the within() function - are your
geometries complex?
dave
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
