[postgis-users] Installing PostGIS
dhouston at beyondcompliance.ca
Thu Jul 29 15:38:41 PDT 2004
Hi Eric,
Yes, you need compiled PostgreSQL source code to install PostGIS. I'm pretty
sure this doesn't come with Fedora 2. You can compile and install a new
version of PostgreSQL or use compiled PostgreSQL source code to hook PostGIS
into your operating system installed PostgreSQL. I am not at work-work right
now (working on the muscle car), but if you can wait until tomorrow I will
send you a document I wrote that leads you step-by-step through a complete
PostGIS install into your operating system installed PostgreSQL.
How does that sound?
Now back to tweaking..., the car that is.
Eric Fegraus (fegraus at nceas.ucsb.edu) wrote:
> Thanks, i guess the problem is finding the postgresql contrib directory in
> the pre-installed PostgreSQL version that came with Fedora 2? Anyone know
> where this is or if it exists (I can't find it) ?....otherwise seems like i
> need to re-install PostgreSQL.
> Thanks!
> eric
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Robert
> W. Burgholzer
> Sent: Thursday, July 29, 2004 2:41 PM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] Installing PostGIS
> Not real experienced myself, but are you un-packing the postgis source tree
> inside /usr/local/psql/contrib/?
> If so, you need to be in the postgresql source directory under contrib. This
> would require that the postgresql be installed from source, or at least have
> a source tree. See:
> http://postgis.refractions.net/docs/c59.
> <http://postgis.refractions.net/docs/c59.html> html
> Sorry if I am totally off here,
> r.b.
> At 01:08 PM 7/29/2004 -0700, you wrote:
> Hello,
> Rookie question. I'm installing PostGIS (postgis-0.8.2.tar.gz) with the
> PostgreSQL 7.4.2 on Fedora 2. I'm getting a "make" error when running
> /usr/share/pgsql/contib.
> I've looked at the RPMs but there doesn't seem to be one for PostgreSQL
> 7.4.2.
> Makefile:38: ../../src/Makefile.global: No such file or directory
> Makefile:160: /src/Makefile.shlib: No such file or directory
> make: *** No rule to make target `/src/Makefile.shlib'. Stop.
> Any ideas?
> Thanks,
> Eric
> postgis-users mailing list
> Robert Burgholzer
> Environmental Engineer
> MapTech Inc.
> http://www.maptech-inc.com/
