[postgis-users] Distance function error if outside the boundary
Tom Melhuish
tmelhuish at webinsightsinc.com
Fri Jul 30 10:17:45 PDT 2004
I forgot to add the software versions I'm running:
Postgis 0.8.1
Postgresql 7.4.1
DBI 1.40
Redhat 9.0
Thanks again,
tom
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Tom
Melhuish
Sent: Friday, July 30, 2004 12:20 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Distance function error if outside the boundary
I'm executing the following Postgis DISTANCE function and if I select
the spatial object within the distance boundary the command works fine,
but I get the following error message in the Postgresql log:
ERROR: cursor "mycursor" does not exist
When I select the spatial object out side the command fails and I get
the following in the Postgresql log file.
ERROR: syntax error at or near ")" at character 144
LOG: could not send data to client: Connection reset by peer
LOG: could not send data to client: Broken pipe
LOG: unexpected EOF on client connection
The Apache log gives me:
Premature end of script headers:
If I copy either SQLcommand and execute it in psql it runs fine. With
no error messages in the postgresql log file.
Below is the code snippet
$SQLcommand=qq(SELECT layer, ncpin, mapsheet, ownername, addr1, addr2,
addr3, city, state, zip, book, page, value, acreage, pflag, revalue,
market FROM jccondo WHERE the_geom &&
GeometryFromText('BOX3D(2103178.38307993 558215.2516,2173267.36692007
611928.4437)',1) AND Distance(GeometryFromText('POINT(2170383.04659743
579103.715194444)',1),the_geom) < 1401.77967680279);
my $stmt = $dbh->prepare($SQLcommand) || &AppletMsg("The table name
doesn't exist or one of the attrribute names are not valid...
$GisDataSrc","error");
$stmt->execute() or &AppletMsg("Can't execute select items on
$GisDataSrc - $DBI::errstr ","error");
$colctr=1;
while (@tname = ($stmt->fetchrow_array())) {
foreach $value (@tname) {
if ($colctr == $NumAttrItems+1 ){
$ItemNum++;
$colctr=1;
$QueryResultsmatrix[$ItemNum]->[$colctr]=$value
$colctr++;
$stmt->finish();
If I need to define a cursor, can someone please send an example or edit
my code to define how this may be done using DBI.
Thanks in advance for your help.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20040730/cbf602d7/attachment.html>
