[postgis-users] spatial index use
Laurent PIERRE
laurent.pierre at edf.fr
Tue Jun 1 02:10:25 PDT 2004
I have problems with the query planner :
using table
Table "public.isis_entreprise"
Column | Type
| Modifiers
id | integer | not null default
nextval('public.isis_entreprise_id_seq'::text)
coord | geometry |
Indexes:
"isis_entreprise_pkey" primary key, btree (id)
"i_entreprise_coord" gist (coord)
Check constraints:
"$1" CHECK (srid(coord) = 102582)
"$2" CHECK (geometrytype(coord) = 'POINT'::text OR coord IS NULL)
the query
select *
from
isis_adresse_geo p,
isis_adresse_geo g2
where
p.id = 2709333 and
GeometryFromText('BOX3D('
|| X(p.coord)-100000
|| X(p.coord)+100000
|| Y(p.coord)-100000
|| Y(p.coord)+100000
||')',SRID(p.coord))
&& g2.coord
is 'explained' as
Nested Loop (cost=0.00..310072.33 rows=272158 width=434)
Join Filter: (geometryfromtext(((((((((('BOX3D('::text ||
((x("outer".coord) - 100000::double precision))::text) || ' '::text) ||
((x("outer".coord) + 100000::double precision))::text) || ','::text) ||
((y("outer".coord) - 100000::double precision))::text) || ' '::text) ||
((y("outer".coord) + 100000::double precision))::text) ||
')'::text))::geometry, srid("outer".coord)) && "inner".coord)
-> Index Scan using adresse_geo_id on isis_adresse_geo p
(cost=0.00..3.01 rows=1 width=217)
Index Cond: (id = 2709333)
-> Seq Scan on isis_adresse_geo g2 (cost=0.00..119558.79
rows=2721579 width=217)
(5 rows)
the planner is unable to take advantage of the spatial index ...
leading to very poor performances :(
Is there a solution to force the planner ?
Laurent
