[postgis-users] Incorrect results from queries specifying an SRID
strk
strk at keybit.net
Tue Jun 1 03:37:56 PDT 2004
On Tue, Jun 01, 2004 at 11:09:42AM +0100, Mark Cave-Ayland wrote:
> > -----Original Message-----
> > From: postgis-users-bounces at postgis.refractions.net
> > [mailto:postgis-users-bounces at postgis.refractions.net] On
> > Behalf Of Paul Ramsey
> > Sent: 28 May 2004 21:10
> > To: PostGIS Users Discussion
> > Subject: Re: [postgis-users] Incorrect results from queries
> > specifying an SRID
> > cp wrote:
> > > My expectation
> > > would be for postgis to automatically transform the
> > coordinates to match
> > > the SRID of the geometries stored in the table (4267) or at
> > least to
> > > give me an error.
> > You should be getting an error, that is the only noticable bug. SRID
> > mismatches are supposed to raise errors (to prevent precisely the
> > problem you demonstrate going quietly unnoticed).
> Hmmm I think this is another symptom of not having RECHECK specified in
> the operator class - I thought that strk committed this change after we
> brought up the discussion earlier this year? It looks like it's only
> specified for PostgreSQL 7.1 at the moment.
> [looks through the source...] It's definitely not in postgis_7*_end.sql
> for >= 7.2. strk, did this get lost somewhere in your changes for
> rebuilding postgis.sql?
postgis_7*.sql are obsolete code.
The new enabler script is postgis.sql.in
It contains RECHECK clauses for PG73,74,75 in CREATE OPERATOR CLASS
--strk;
> Cheers,
> Mark.
> Mark Cave-Ayland
> Webbased Ltd.
> Tamar Science Park
> Derriford
> Plymouth
> PL6 8BX
> England
> Tel: +44 (0)1752 764445
> Fax: +44 (0)1752 764446
> This email and any attachments are confidential to the intended
> recipient and may also be privileged. If you are not the intended
> recipient please delete it from your system and notify the sender. You
> should not copy it or use it for any purpose nor disclose or distribute
> its contents to any other person.
> postgis-users mailing list
