[postgis-users] more query optimization
Paul Ramsey
pramsey at refractions.net
Tue Jun 1 07:33:33 PDT 2004
Do you have USE_STATS on, and have you run the update statistics
function? That is the magic incantation, generally...
On Tuesday, June 1, 2004, at 06:41 AM, Robert W. Burgholzer wrote:
> I am trying to do a join using views, and am having some serious
> performance issues as a result.
> I have a postgis table, with soil map shapes and ID's. I have three
> other tables that when linked together in a view give the names and
> characteristics of the soils in the soil map, and the variation of the
> characteristics by soil layer, indexed by a key they share with the
> soil shape table.
> All of these layers can be queried fairly quickly, although my soil
> map table has around a half million entries in it, with about 4,000
> unique ID's that map to the other two data tables. When I just pull
> the soil layer shapes into my arcview view (using Armin Burger's
> avpgconn) without joining on the property data, the process takes
> about 10-20 seconds depending on the width of the view. When I pull it
> with one soil layer (the top layer only) properties view joined, I get
> about 10 minutes as the result, and when I join both the top soils
> layer view and the second soil layer view my query time is about 15-20
> minutes.
> I surmise from the query explain output that the join on the key
> properties between these layers is occurring before the soil shape
> records are weeded out to the spatial extent (which is a very low cost
> selection since they are indexed), thus, all half million records are
> being joined first, then the ones in the spatial extent are being
> grabbed. What I would like to do is reverse this order. Does anyone
> have any idea how to do this?
> Thanks in advance.
Paul Ramsey
Refractions Research
Email: pramsey at refractions.net
Phone: (250) 885-0632
