[postgis-users] more query optimization
Robert W. Burgholzer rburgholzer at maptech-inc.com
Tue Jun 1 08:48:26 PDT 2004
OK,
the USE_STATS option was indeed set to 1 in my postgis makefile, I have run
the following query:
select update_geometry_stats();
And voila! the query comes back in under a minute,  perfectly acceptable.
Now, do you suggest I include this update_geometry_stats() call in my daily
vacuum job?
Thanks a bunch,
r.b.
At 07:33 AM 6/1/2004 -0700, you wrote:
>Do you have USE_STATS on, and have you run the update statistics function?
>That is the magic incantation, generally...
>On Tuesday, June 1, 2004, at 06:41 AM, Robert W. Burgholzer wrote:
>>I am trying to do a join using views, and am having some serious
>>performance issues as a result.
>>I have a postgis table, with soil map shapes and ID's. I have three other
>>tables that when linked together in a view give the names and
>>characteristics of the soils in the soil map, and the variation of the
>>characteristics by soil layer, indexed by a key they share with the soil
>>shape table.
>>All of these layers can be queried fairly quickly, although my soil map
>>table has around a half million entries in it, with about 4,000 unique
>>ID's that map to the other two data tables. When I just pull the soil
>>layer shapes into my arcview view (using Armin Burger's avpgconn) without
>>joining on the property data, the process takes about 10-20 seconds
>>depending on the width of the view. When I pull it with one soil layer
>>(the top layer only) properties view joined, I get about 10 minutes as
>>the result, and when I join both the top soils layer view and the second
>>soil layer view my query time is about 15-20 minutes.
>>I surmise from the query explain output that the join on the key
>>properties between these layers is occurring before the soil shape
>>records are weeded out to the spatial extent (which is a very low cost
>>selection since they are indexed), thus, all half million records are
>>being joined first, then the ones in the spatial extent are being
>>grabbed. What I would like to do is reverse this order. Does anyone have
>>any idea how to do this?
>>Thanks in advance.
>      Paul Ramsey
>      Refractions Research
>      Email: pramsey at refractions.net
>      Phone: (250) 885-0632
>_______________________________________________
>postgis-users mailing list
>postgis-users at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-users
Robert Burgholzer
Environmental Engineer
MapTech Inc.
http://www.maptech-inc.com/
