[postgis-users] Fwd: [Mapserver-users] WMS GetFeatureInfo on PostGIS slow?
Paul Ramsey
pramsey at refractions.net
Tue Jun 1 13:59:19 PDT 2004
What is your DATA statement, and what indexes do you have on your table?
Bart van den Eijnden wrote:
> Hi,
> I got no answer on the Mapserver list, maybe somebody here knows the
> answer. I am using the Win32 snapshot from Mark in combination with
> Mapserver 4.2 b3.
> Is the performance problem caused by the fact that the cursor is not
> used for some reason?
> Thanks in advance.
> Best regards,
> Bart
> ------- Forwarded message -------
> From: Bart van den Eijnden <bartvde at xs4all.nl>
> To: "mapserver-users at lists.gis.umn.edu" <mapserver-users at lists.gis.umn.edu>
> Subject: [Mapserver-users] WMS GetFeatureInfo on PostGIS slow?
> Date: Sun, 30 May 2004 14:53:37 +0200
>> Hi list,
>> I have started my first adventures with PostGIS and I am quite
>> impressed by the speed with which the map is drawn.
>> I have a polygon layer with 1,5 million records.
>> As I said, map performance is good. But when I use GetFeatureInfo on
>> the PostGIS layer, it takes more than 5 seconds for Mapserver to come
>> back with the result. In the PostgreSQL console I see:
>> ERROR: cursor "mycursor" does not exist
>> Is this normal performance for GetFeatureInfo on PostGIS, or can I
>> tweak something to speed this up? I am using Mapserver 4.2 beta 3, as
>> this is the latest Win binary available.
>> Thanks in advance.
>> Best regards,
>> Bart
>> Mapserver-users mailing list
>> Mapserver-users at lists.gis.umn.edu
>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
__
| Paul Ramsey
| Refractions Research
| Email: pramsey at refractions.net
| Phone: (250) 885-0632
\_
