[postgis-users] Fwd: [Mapserver-users] WMS GetFeatureInfo on PostGIS slow?
Bart van den Eijnden
bartvde at xs4all.nl
Tue Jun 1 14:30:17 PDT 2004
Hi Paul,
Oops, I did this, followed by a vacuum analyze, and now no maps are coming
at all :(
(Restarting the db did not help).
Mapserver gives me an internal server error, nothing special in the Apache
error log.
Yes, I will be in Ottawa and most certainly will buy you a beer.
Any ideas?
Best regards,
Bart
On Tue, 01 Jun 2004 14:10:14 -0700, Paul Ramsey <pramsey at refractions.net>
wrote:
> create index top50_oid_idx on top50 (oid);
> Are you coming to Ottawa so you can buy me a beer? :)
> Bart van den Eijnden wrote:
>> Hi Paul,
>> this is my DATA statement:
>> DATA "the_geom from top50"
>> I have created the following index:
>> CREATE INDEX top50_geom_idx ON top50 USING GIST (the_geom
>> GIST_GEOMETRY_OPS);
>> Data was loaded through shp2pgsql.
>> Best regards,
>> Bart
>> On Tue, 01 Jun 2004 13:59:19 -0700, Paul Ramsey
>> <pramsey at refractions.net> wrote:
>>> What is your DATA statement, and what indexes do you have on your
>>> table?
>>>> Hi,
>>>> I got no answer on the Mapserver list, maybe somebody here knows the
>>>> answer. I am using the Win32 snapshot from Mark in combination with
>>>> Mapserver 4.2 b3.
>>>> Is the performance problem caused by the fact that the cursor is not
>>>> used for some reason?
>>>> Thanks in advance.
>>>> Best regards,
>>>> Bart
>>>> ------- Forwarded message -------
>>>> From: Bart van den Eijnden <bartvde at xs4all.nl>
>>>> To: "mapserver-users at lists.gis.umn.edu"
>>>> <mapserver-users at lists.gis.umn.edu>
>>>> Subject: [Mapserver-users] WMS GetFeatureInfo on PostGIS slow?
>>>> Date: Sun, 30 May 2004 14:53:37 +0200
>>>>> Hi list,
>>>>> I have started my first adventures with PostGIS and I am quite
>>>>> impressed by the speed with which the map is drawn.
>>>>> I have a polygon layer with 1,5 million records.
>>>>> As I said, map performance is good. But when I use GetFeatureInfo on
>>>>> the PostGIS layer, it takes more than 5 seconds for Mapserver to
>>>>> come back with the result. In the PostgreSQL console I see:
>>>>> ERROR: cursor "mycursor" does not exist
>>>>> Is this normal performance for GetFeatureInfo on PostGIS, or can I
>>>>> tweak something to speed this up? I am using Mapserver 4.2 beta 3,
>>>>> as this is the latest Win binary available.
>>>>> Thanks in advance.
>>>>> Best regards,
>>>>> Bart
>>>>> _______________________________________________
>>>>> Mapserver-users mailing list
>>>>> Mapserver-users at lists.gis.umn.edu
>>>>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
