[postgis-users] Fwd: [Mapserver-users] WMS GetFeatureInfo on PostGIS slow?
Bart van den Eijnden
bartvde at xs4all.nl
Tue Jun 1 14:44:18 PDT 2004
Solved it, stupid me. Feature info is running smooth now.
I was running in the wrong Apache server (I have 2 installed, but with a
different version of mapserv).
I will be joining one of the PostGIS workshops for sure in Ottawa :)
But the index on the oid field is not in the MUM 2003 workshop document if
I am not mistaken.
Thanks alot. See you in Ottawa.
Best regards,
Bart
On Tue, 01 Jun 2004 23:30:17 +0200, Bart van den Eijnden
<bartvde at xs4all.nl> wrote:
> Hi Paul,
> Oops, I did this, followed by a vacuum analyze, and now no maps are
> coming at all :(
> (Restarting the db did not help).
> Mapserver gives me an internal server error, nothing special in the
> Apache error log.
> Yes, I will be in Ottawa and most certainly will buy you a beer.
> Any ideas?
> Best regards,
> Bart
> On Tue, 01 Jun 2004 14:10:14 -0700, Paul Ramsey
> <pramsey at refractions.net> wrote:
>> create index top50_oid_idx on top50 (oid);
>> Are you coming to Ottawa so you can buy me a beer? :)
>> Bart van den Eijnden wrote:
>>> Hi Paul,
>>> this is my DATA statement:
>>> DATA "the_geom from top50"
>>> I have created the following index:
>>> CREATE INDEX top50_geom_idx ON top50 USING GIST (the_geom
>>> GIST_GEOMETRY_OPS);
>>> Data was loaded through shp2pgsql.
>>> Best regards,
>>> Bart
>>> On Tue, 01 Jun 2004 13:59:19 -0700, Paul Ramsey
>>>> What is your DATA statement, and what indexes do you have on your
>>>> table?
>>>>> Hi,
>>>>> I got no answer on the Mapserver list, maybe somebody here knows the
>>>>> answer. I am using the Win32 snapshot from Mark in combination with
>>>>> Mapserver 4.2 b3.
>>>>> Is the performance problem caused by the fact that the cursor is not
>>>>> used for some reason?
>>>>> Thanks in advance.
>>>>> Best regards,
>>>>> Bart
>>>>> ------- Forwarded message -------
>>>>> From: Bart van den Eijnden <bartvde at xs4all.nl>
>>>>> To: "mapserver-users at lists.gis.umn.edu"
>>>>> <mapserver-users at lists.gis.umn.edu>
>>>>> Subject: [Mapserver-users] WMS GetFeatureInfo on PostGIS slow?
>>>>> Date: Sun, 30 May 2004 14:53:37 +0200
>>>>>> Hi list,
>>>>>> I have started my first adventures with PostGIS and I am quite
>>>>>> impressed by the speed with which the map is drawn.
>>>>>> I have a polygon layer with 1,5 million records.
>>>>>> As I said, map performance is good. But when I use GetFeatureInfo
>>>>>> on the PostGIS layer, it takes more than 5 seconds for Mapserver to
>>>>>> come back with the result. In the PostgreSQL console I see:
>>>>>> ERROR: cursor "mycursor" does not exist
>>>>>> Is this normal performance for GetFeatureInfo on PostGIS, or can I
>>>>>> tweak something to speed this up? I am using Mapserver 4.2 beta 3,
>>>>>> as this is the latest Win binary available.
>>>>>> Thanks in advance.
>>>>>> Best regards,
>>>>>> Bart
>>>>>> _______________________________________________
>>>>>> Mapserver-users mailing list
>>>>>> Mapserver-users at lists.gis.umn.edu
>>>>>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
