[postgis-users] Win32 PostgreSQL 7.5/PostGIS snapshot update
Mark Cave-Ayland
m.cave-ayland at webbased.co.uk
Thu Jun 3 04:39:45 PDT 2004
Hi guys,
Just to let you know I've updated my Win32 snapshot again at
http://www.webbased.co.uk/mca/pgsql75win.zip. The CVS snapshot of GEOS
that I used in the original build was found to have some bugs in it
which could cause out of memory errors and/or the backend to die when
using certain GEOS functions. This version of the snapshot is compiled
against the proper GEOS 1.0 release and now things appear to work as
they should. If you are not using any GEOS function then this will not
affect you! Note I have not upgraded the PostgreSQL snapshot so you can
copy your existing data/ directory into the new distribution and
continue working as before.
Many thanks to David Techer for his help and patience solving this
problem.
Mark.
Mark Cave-Ayland
Webbased Ltd.
Tamar Science Park
Derriford
Plymouth
PL6 8BX
England
Tel: +44 (0)1752 764445
Fax: +44 (0)1752 764446
This email and any attachments are confidential to the intended
recipient and may also be privileged. If you are not the intended
recipient please delete it from your system and notify the sender. You
should not copy it or use it for any purpose nor disclose or distribute
its contents to any other person.
