[postgis-users] Incorrect results from queries specifying an SRID
    strk
    strk at keybit.net
    Fri Jun  4 09:56:29 PDT 2004
On Fri, Jun 04, 2004 at 10:43:53AM -0600, cp wrote:
> Mark,
> Thanks for your help.  If I wanted to attempt to fix this where would I
> start looking?  See also my other email about the box3d casts.  Would it
> be possible to remove them somehow?
Current CVS of postgis contains an expand() function that does not
cast to BOX3D. You should be able to use it with success.
--strk;
> Corey
> Mark Cave-Ayland wrote:
> >Hi Corey,
> >Hmmm..... I can't see why this one doesn't work. All I can think of is
> >that the BOX3D cast causes the SRID not be set or set incorrectly. I'll
> >try and have a look at this in the near future, however I'm not sure
> >exactly when I'll be able to get around to it.
> >Cheers,
> >Mark.
> postgis-users mailing list
